11-11-2017, 09:13 AM
12v / USB Power - how to make always hot?
I have never really needed an always on/hot power supply....until now. Is there an easy way to make the 12v plug or USB plugs always have power when the 4R is off?
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
11-11-2017, 10:11 AM
Banned
Banned
yeah, the easy way is to run a new feed from the battery to an always on 12v plug where you want it (or from a new distribution panel from a new feed if you want to be fancy and plan on adding other accesories)
11-11-2017, 10:12 AM
Real Name: Neal
Real Name: Neal
The easiest way that I know of is to just run a wire in through the firewall to the spot you want to add the always on outlet.
I just did this yesterday to my rear outlet. I ran a wire from the hot side on the back of the power convertor under my passenger seat. You can also wire to the fuse box with a fuse tap to a spot that always has power. You cut the green wire and tap into that, make sure to cap off the other side of the green wire or it my short out when you turn the key on. Also
@ Antman
has a good wirte up on this as well.
11-11-2017, 11:51 AM
One would think that there would have to be a simple way of just jumping the connection in the box to be constant rather than running new wires. I do not have a schematic for the truck yet but will investigate it when I do. I know in the 1st gen Taco you need only pull the pwr outlet relay and add a jumper
'18 Runner
1986 LHD BJ73 Land Cruiser
2004 S/C Tacoma TRD 4x4
'72 GTO
WWW.INLEADWETRUST.COM
11-11-2017, 11:55 AM
I'd like to know this as well. Kinda frustrating to have to run wires everywhere. But I get to know the truck better I guess.
11-11-2017, 12:36 PM
I used 2 add a circuit to jump a constant on fuse to the switched 12v plugs.. searching for pics an will post if i find them
11-11-2017, 12:51 PM
11-11-2017, 06:14 PM
I will be trading in with-in a year so was not looking to run wires through the firewall or anything too complicated for now. It looks like a couple of the other options might be a quick fix for it though and do-able! Thanks for the responses!
04-23-2018, 03:13 PM
I’m need to tap the 12V outlet for a rear view camera. How did you access the wiring to the 12V jack? Did you pull the connector with the Green/White wires or does the outlet panel pop out from the front?
04-23-2018, 08:54 PM
Is keeping an iPad mini hooked up to an always on 12v usb gonna drain the battery enough that it won't start?
04-23-2018, 09:05 PM
Real Name: Swartwood
Probably be fine.
No, but probably not necessary. If you drive more than 40 minutes a week I'd assume an ipad mini would stay charged perfectly fine. I would advise not using the 4runner USB as it has a very low current threshold. I'd use a 10W or more USB plug in the 12V outlet. Also the DC converter will always use some power if you do this due to inefficiency. Probably rather have to recharge the mini than risk ruining my starting battery.
Good USB Charger
10 TE - KDSS - Icon Suspension - 285/70/17 Hankook MTs - 4.56 nitro Gears - URD equal length headers
Shrockworks front bumper and sliders - MT Rear bumper- RCI aluminum skids - Dif breather mod - K9 Rack - Warn 10S Winch
Come ride with me: PDX 4X4
02-10-2019, 08:11 PM
Thank you for this tip. It worked out perfectly without any added wiring.
One piece of advise is it seems its polarity specific so be sure to plug the add a circuit in the exact orientation as the picture, also put the fuse in the same socket closest to the wire. I did it the wrong way and it kept my radio on instead of the 12v sockets. Hope this helps anyone that runs into this issue
02-10-2019, 08:13 PM
Great tip. Thanks
02-10-2019, 08:14 PM
Awesome tip. Worked like a charm
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
