08-12-2022, 02:39 PM
How important is this heat shield?
So drove from DC to Crystal Coast NC...about a 6-hour drive. There was a stretch where I hit 100mph. Upon arrival, there was an awful racket under the truck. Didnt seem to be functional though so drove back.
Today I was able to get under the car and found that the heat shield that sits above the exhaust pipe on the right rear had completely broken loose and was resting on the exhaust pipe. I was able to shimmy it out. Guessing the force of air at 100mph probably broke it loose. It's aluminum so no apparent corrosion.
It's obviously there for a reason, but how important is it?
I have a 3 hour drive to the beach tomorrow and then back next weekend. I'm sure I'm ok to make that drive but I'm wondering if this is something I even need to bother replacing at all or if I'm going to blow up driving down the road at some point because of heat damage
4runner exhaust heat shield
2014 LE - Attitude Black w/Redwood - MODS - Status Mastadon 20x9+5 Carbon Graphite w/Yokohama G015 275/55/20, TRD Pro Front End, RCI Aluminum Skids Bumper-Trans, Rhino-Rack Pioneer 76x49 Backbone System (Chopped to 68x49), GTR Carbide LED Headlamps, DD SS3 MAX Amber Fogs, Gibson Catback Side Exit Dual Tip Black Ceramic Exhaust, Tint: 20% Front/%35 Rear/Limo sunroof, Black Door Handle Covers -
08-12-2022, 03:47 PM
Mine came off as well, never thought about replacing it. You are right, it does make quite a racket.
08-12-2022, 04:42 PM
might matter when summer is in full swing again.. if you got it just put it back on
08-12-2022, 06:48 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
08-12-2022, 07:20 PM
dont think summer temps have any effect on how hot the exhaust is getting
08-12-2022, 09:10 PM
Is there any way you can put some bolts with washers on each side and nuts to re-secure it?
Best Regards,
Saker
08-12-2022, 09:28 PM
No hurry
When driving there is plenty of airflow to keep the area cool. But I would get it reinstalled bc stop n go traffic will cause things to get hot.
08-13-2022, 12:01 AM
good point and living in DC metro area that's pretty regular!
08-13-2022, 12:08 AM
I supposed I could. It took a bit to get it out so I wonder if I would have to drop the catback to get it on. If that's the case wondering if the ROI is worth it.
08-13-2022, 11:06 AM
If Toyota could save a penny by NOT installing something that wasn't deemed necessary, they would. Personally, I would reinstall with washers, etc. Or replace it.
08-13-2022, 02:11 PM
I’ve been without mine for almost 2 years, you will have no issues running without it.
08-13-2022, 02:44 PM
why wouldn't it when the exhaust heat is rising into the cabin or maybe wait til after winter to install and use it as temp seat or feet warmers?
08-13-2022, 04:32 PM
I’ve also been without two of the shields for a few years now (also in DC) with no apparent issues. I think you’ll be good. Cheers
2013 4Runner
08-13-2022, 04:37 PM
When I think of heat shields, I think of the space shuttle Columbia (obviously a terrible tragedy).
Point is, if you have it, no reason not to out it back on. Toyota would not have spent the money engineering it, if it was not needed or beneficial. Its not a cosmetic part, so it does serve a function.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
08-13-2022, 06:44 PM
Only rattles, been with out for years. Don’t miss it.
