Happy to share that I got everything setup and working properly. Fog light issue was something simple... The polarity on the adapter harness was flipped and backwards. Flipped them around 180 degrees and re clicked them in and bam then work! My dumb luck is I hooked both of them up wrong.
Morimoto designed their adapter harnesses for the 4bangers so that if you install them either way you'll receive an audible click when attaching and it will fit. You'd think that they would make them so there's only one way to click them in so that people like me don't have to go troubleshooting
As for the headlights... All I needed was the morimoto wire harness adapter that is for TRD pro and limited models. Turns out from what I'm reading that all 2021+ models will require this harness. Hopefully this helps someone else out with the same issues.
Originally Posted by amir_gh
I went through two pairs over a year. First the DRL corner went out. Then I got GEN II for my replacement. One of the projector went out and started to flicker. At that point I lost confidence on them. I took them out and I got the OEM 2022 LED headlights. Very happy with them.
I certainly hope that doesn't happen with mine. I have the Gen II's.. and yes there have been stories that the Gen 1's had major issues. Did morimoto not offer any replacements under any warranty?
