View Poll Results: OEM spindle failure
Spindle failure - Primarily Go-fast usage 2 5.71%
2 5.71%
Spindle failure - Primarily RockCrawler usage 3 8.57%
3 8.57%
No Failures - Highway use only 6 17.14%
6 17.14%
No Failures - Moderate/Overland off-road use 15 42.86%
15 42.86%
No Failures - Rock gardens/Desert whoops/moderate Go-fast 8 22.86%
8 22.86%
Bacon 1 2.86%
Bacon
1 2.86%
Voters: 35. You may not vote on this poll
Old 08-14-2022, 09:23 PM #1
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
Bent 5th gen front Spindles - Your experience?
I'd like to hear about your experience with unmodified OE spindle strength. I've heard rumors of them being less than robust and Total Chaos fab puts out a kit to prevent bending/failure:
Spindle gusset kit with swaybar - $87 smackers:
Toyota 4Runner 2010-2022 SPINDLE GUSSETS - WITH SWAYBAR MOUNTS | TOTAL CHAOS FABRICATION
These gussets were designed to reinforce a known weak link on your Toyota. Unexpected harsh front impacts at high speed or while under braking can cause catastrophic damage to your factory spindle / knuckle. These weld-on gussets were ogiginally designed for the US military and their 8000 lb. body armored vehicles. Dont get stranded on the trail. Protect your OE parts.
But who here has had this failure, or seen it first hand?
Can you share the details/tire size/usage when failed?
Or have you been wheeling hard, rock strewn trails without much issue to report?
I don't have a big issue with this modification - I'm all about reinforcing areas of concern, but this mod seems to prevent the use of stock TRD OR wheels, and forces us to replace them with either spacers or aftermarket wheels, which we're not to keen on. (unless we have to)
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 08-14-2022, 10:02 PM #2
honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of
no issues here (plenty of full compression hits going 30-50 both off camber and head on). i already run spacers on my trail wheels. I have a double shear UCA mount kit i want to install after that I will be gusseting my spindles. probably with the DRT kit since he's local.
i've managed to damage the UCA through bolt but not the spindle lol
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS sway bar controller
Old 08-14-2022, 10:56 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
I think of this as an insurance policy...do it if you can afford it.
I run em, and it gives me a peace of mind since i like to play in the desert more than i like playing in rock gardens.
If you buy wheels with a certain amount of backspacing and offset, you can get away with not running spacers.
Old 08-15-2022, 01:28 AM #4
SC2388's Avatar
SC2388 SC2388 is offline
SC2388 is on a distinguished road
SC2388's Avatar
I’ve seen a bent one on an FJ (same design). I got the kit after that just for the extra peace of mind and it’s only like $100 plus any labor that you have to have done to have them fab’d (these kits do require a little cutting/grinding to get it to fit just right IME). The guy who bent the FJ one said he was going like 2mph. I never had issues with mine and I haven’t ever seen one bend firsthand, so idk, but maybe if you hit it a certain way it is susceptible ?? It definitely doesn’t seem as beefy as a control arm.
The Total Chaos Kit is a nice kit. They also make a cam tab kit. I’ve seen cam tabs bent on a pretty new Tacoma to the point the truck couldn’t be aligned. There is a way you can do permanent alignment but didn’t get too deep into that and it’s a bridge I will cross if I ever get there
Current: 2018 SR5P XP; Dobinsons c59-314/MRA59-A574(F) c59-505/MRA59-A701(R); Dobinsons PS59-4030 (driver); Dobinsons UCAs, rear sway bar links, and diff drop; Nitto Trail Grap 285/70R17; Bash Fabrication Sliders; Bash Fabrication lo-pro front bumper; Badland Apex 12k winch; Baja Designs Squadron fog lights and 20" S8; Diode Dynamics LED reverse lights; Victory 4x4 crossbars; BPFabricating molle pet barrier; Victory 4x4 front/mid/tcase skids; EVC throttle controller; front sway bar delete; ARB Diff Breather kit; Spidertrax; Total Chaos weld on spindle gussets, BMC with pinch weld mod
SC2388 is offline   Reply With QuoteReply With Quote
Old 08-15-2022, 01:40 AM #5
The Total Chaos Kit is a nice kit. They also make a cam tab kit. I’ve seen cam tabs bent on a pretty new Tacoma to the point the truck couldn’t be aligned. There is a way you can do permanent alignment but didn’t get to deep into that and it’s a bridge I will cross if I ever get there
Marlin Crawler has an awesome gusset system for the whole LCA mount area and encompasses the cam washers. i'm running that one, we couldnt keep an alignment worth anything once the flimsy toyota setup failed. the TC one can be ran with it as well if you wanna get extra crazy.
Old 08-15-2022, 01:48 AM #6
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is a jewel in the rough blksubykid is a jewel in the rough blksubykid is a jewel in the rough blksubykid is a jewel in the rough
blksubykid's Avatar
I run the TC spindle gussets and the Marlin Crawler cam gussets. The spindle gussets are an insurance policy and I did it since I was doing the cam gussets. I never had an issues prior but I did knock my alignment off a lot.
blksubykid is offline   Reply With QuoteReply With Quote
Old 08-15-2022, 02:15 AM #7
mrblah's Avatar
mrblah's Avatar
cam gussets is a no-brainer......
after every offroad trip i had to get my shit re-aligned, and after a few big trips my tabs were flatten/destroyed.
SD truck shop/ Built Right fabrication cam gusset
SD truck shop/ Built Right fabrication spindle gusset.
The SD truck shop/ BR fabrication cam gusset is alot stronger than just the TC version, but not as crazy beefy as the MC version. You can kind of see it in the pic, its boxed in and welded to the subframe. Only thing is, they don't sell a kit for this, they do in-house fabrication if i remember correctly.
Also, in the pic, i have plenty of clearance against the spindle gusset but im running a wheel with 3.5BS and -38 offset.
Can't believe nobody has pics!!!NEANDERTHALS!!!!
Bent 5th gen front Spindles - Your experience?-thumbnail-16-jpeg
Old 08-15-2022, 09:36 AM #8
hahaha i've given up on uploading to this site. marlin crawler gussets for pic reference just imagine all the beef and thiccness possible, then apply it to where the LCA pivots. lol
Old 08-15-2022, 09:56 PM #9
Yeah, trying to avoid buying wheels if we don’t need to.
Old 08-16-2022, 07:35 AM #10
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
I have the TC weld on spindle gusset kit with swaybar mounts and Marlin Crawler cam tab kit. Tired of needing alignments.
2016 TEP
JPOVS is offline   Reply With QuoteReply With Quote
Old 08-16-2022, 09:06 AM #11
Thanks for posting.
Just for clarity, you WE’RE tired of needing alignments? As in, the cam tab gussets solved that?
Thanks in advance!
Old 08-16-2022, 09:30 AM #12
JPOVS's Avatar
JPOVS's Avatar
It appears to have fixed it. Since I’ve done the mod I’ve only been off-roading or overlanding a few times. Been getting back into backpacking and leaving the 4Runner at home.
2016 TEP
Old 08-16-2022, 02:47 PM #13
thanks for the info.
Spidertrax spacers seem to be good choice, and if we went with a set of gussets, I think it's a choice between $140.00 for quality spacers, or $600-1000.00 for a new set of wheels that'll still allow 33-34's to tuck into the fenders.
We don't want to compromise safety with rock gardens and moderate rock ledges in our future (if the spacers are at risk of failing), but again, if we can avoid ditching our stock wheels, we'd prefer it.
Old 08-16-2022, 08:51 PM #14
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
What I think would be interesting to know if bent spindles have any association with poly bushings. I suspect poly bushings significantly increase the peak forces on the spindle. But most damaged may be from too hard of hits on the bump stops. So maybe softer bumps and more compression damping is the better fix.
Jetboy is online now   Reply With QuoteReply With Quote
Old 08-17-2022, 02:33 PM #15
That's an interesting thought - i also find it interesting that total Chaos offers re-designed front suspension components geared towards go-fast that might adjust suspension angles, and how it actually cycles. Maybe they became aware of the problem that is perpetuated or even amplified by some of their proprietary changes, (including your suggestion about different bushing materials used)?
For example, I know that after folks install RCV CV's, some of them quickly find out that they've strengthened a somewhat "Easy" fuse to change out (stock CV's) and therefore move the failure point somewhere else upstream in the drivetrain (Ring and pinion, driveshafts, etc) when the effects of rough terrain, high speeds or oversized tires start to manifest in material failures.
designed , experience , gussets , kit , spindle
2 pics added - Play a game...bent, bent and totaled, or I got lucky? northcoast 5th gen T4Rs 2 07-08-2019 09:23 AM
2 sets of hubs and spindles and front axles can deliver to SoCal Tour991 For Sale: Suspension/Wheels/Tires 7 07-03-2016 10:04 AM
WTB: 4WD Front Spindles - 3rd Gen Cree Want to Buy/Trade 2 09-30-2014 06:45 PM
FS 3rd Gen 4wd OEM front Spindles($70) & OEM ABS Sensors($30) Vancouver, WA ryankmasuda For Sale: Suspension/Wheels/Tires 5 07-11-2014 07:43 PM
Bent/deformed front sway bar hour 3rd gen T4Rs 6 06-04-2014 04:56 AM
