08-23-2022, 08:54 PM
#16
alright update on the harness. Lasfit confirmed, eliminating the backlight on the switch isnt doable with their harness. No big deal, i'll buy a Baja Designs harness. Lasfit sent extra Deutsch pigtails in their box, so i can still use the Deutsch connectors on the lights. Just connect those to the BD harness, run my OEM switch on the BD harness and itll be just like my other switches. Backlight on only when the switch is turned on. Not an issue, just a personal preference.
So far, this entire setup seems to be fantastic quality. All of my "gripes" have been non functional things lol. (allen head bolts, length of the bolts, switch backlight, wiring gauge for the switch)
08-23-2022, 09:51 PM
#17
lasfit is in the lighting business not the fastener business.....
jk..lol.
08-24-2022, 01:05 AM
#18
jk..lol.
They've seen my posts, they know i dont hold back. But really, good stuff so far.
08-25-2022, 03:56 PM
#19
jk..lol.
are you the one who cut the brackets down one setting? or am i thinking of someone else? I kinda wanna cut the top hole out, use the next "slot" for the bolts so the light sits closer to the actual a pillar mount.
08-25-2022, 04:03 PM
#20
Not me broski, I’m running sdhq brackets
08-30-2022, 09:02 PM
#21
swapped out the lasfit allen head bolts for some stainless button head allen bolts. also ditched one of the flat washers. so its just bolt, lock washer, bracket, flat washer, light. looks better in my opinion. I was thinking of using a hex head, but i THINK the allen head bolts are less likely to be wrenched off and lights stolen. who knows though.
it looks sleek now, instead of robot antennae sticking out the side of the lights lol. also went to SDHQ and grabbed a BajaDesigns harness. gonna swap that in soon as its no longer 110 out. thankfully in the original packaging Lasfit sent the harness AND extra pigtails for shortening/changing harnesses. 10/10
@ lasfit
08-30-2022, 09:14 PM
#22
@ lasfit
i'm gonna pm you.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
