Old 08-23-2022, 10:32 AM #16
Humble Leader's Avatar
Originally Posted by KiwiCan View Post
Do most owners get more than 60K miles from the system?
I got 152k miles out of my factory XREAS until one shock started weeping. that's 152k miles, not km, so about 240,000km. not bad but I also don't think many people that have XREAS are as lucky as me. I replaced all 4 corners once and next time they fail I don't know if I'd replace them again. my rig is already 10 years old so maybe I'd go with a dobinsons or bilstein or something "simple". those hard lines and actuators won't last forever. I don't mind the ride with them but I also don't have 20" rims, I have 17s with a 265 M+S tire
Old 08-23-2022, 10:45 AM #17
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
I could more.imagine a tendency to buck over large undulations with such a system rather then not handling small imperfections
no its the opposite...worse over small stuff
Grug556 is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 11:18 AM #18
KiwiCan KiwiCan is offline
KiwiCan is on a distinguished road
Originally Posted by Grug556 View Post
Mine were stock 20s with I think Yoks on them. Its not a tire issue as they sidewalls arent super stiff.
I have removed the 20s a few weeks after getting it on one of my Limiteds. Now I only run the following on one limited, the other limited stays stock with 20s and XREAS still so comparisons are easy.
MT Cooper ST Pros 265-70-17 8 inch wheel 40psi-42psi C rated
AT BFG K02 265-70-17 8.5 inch wheel 40 psi E rated
Snows Blizzak DMV2 265-70-17 P rated 32psi
XREAs is an interesting system but like most all in one systems its generally ok on most stuff but never really shines on anything either. I ripped it out and went with Kings, which have been far smoother in comparison, even when valves are set on stiff.
Mud terrains are not going to give a good ride,or handling and road noise will be high,plus terrible mpg.
The xreas system I doubt would be conducive to running aggressive tires.
KiwiCan is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 01:27 PM #19
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
I only have around 3K miles on the vehicle,but coming from a highlander ride is quite good considering the solid rear axle.
There is less brake dive than expected. I test drove a new limited 4yrs ago and it had a lot of brake dive.Around the same.time I also test drove a trd offroad with kdss and that dive was not as apparent,interestingly thre sport feels closer to the offroad from memory but that could be just a bad memory.
Does the trd sport have different suspension tuning to the limited?
my understanding is that the Sport and LE are the same except the LE 4x4 has the AWD/torsen center diff and the Sport has the regular 4wd version. i doubt this makes a handling difference in normal situations, but might be wrong. both have XREAS and the same wheels, so i suspect there is little real difference between the two.
Toffees is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 03:04 PM #20
Most likely as there has been no mention of suspension tuning differences,unless there has been some improvement across the trims in the last 4 years.
It would be interesting to hear from someone who has driven the different trims recently.
Most of those idiots on youtube are clueless.
I was surprised how firm the trd sport felt with the xreas
The fulltime 4wd on limited should improve the handling more than xreas,that is a significant advantage.
arse , fool , shocks , sport , trd
Sport Suspension Ronda Trimble 4th Gen T4Rs 6 08-07-2014 06:35 PM
Value $$ of the XREAS suspension on the Sport.. Jarid7 4th Gen T4Rs 6 06-11-2012 03:59 PM
Sport vs. Limited suspension 2003Can4runner 4th Gen T4Rs 7 03-01-2010 01:39 PM
'04 Sport suspension comparison flcoasterguy 4th Gen T4Rs 15 06-02-2004 01:57 PM
