08-25-2022, 04:53 PM
Changed rear diff fluid today
Today I hit 29k thousand miles on my 4Runner. I decided to change my rear diff fluid at 29k miles. My 21 Tacoma rear diff went out at 8k so I decided to change my 4Runner as a precaution. My question is should I wait until 50k to change the transfer case and front diff since I hardly put it in 4 wheel drive? I used 75w90 gl5.
08-25-2022, 05:36 PM
I'm doing everything at 50K including the transmission.
08-25-2022, 05:47 PM
I don't have a 4R yet - but owned a 2013 FJ Cruiser from new until 2021. The FJ's owners manual said to run 4WD for a few (10?) miles every month. I did this maybe 8 months of the year. I did not offroad much.
Does the 4R require the same?
08-25-2022, 05:49 PM
Yes I believe all Toyota 4wds recommend this but it's just good practice to exercise your 4wd. Just find a straight road.
08-25-2022, 06:27 PM
My FJ manual stated the same as both of my T4R's............... once a month for 10 miles.
Best Regards,
Saker
08-26-2022, 03:56 AM
Real Name: Buck
Real Name: Buck
Interesting your rear diff went out at 8k on your taco; I changed my rear diff fluid on my 2019 4R at 3k and it was under filled from factory. Lots of metal shavings and the fluid was shot. I would defiantly change the T-case and front diff.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
08-26-2022, 05:22 AM
I did both diffs and t-case at 25k on a 2019.
Truck saw consistent 4WD usage in that interval.
Rear diff fluid was similar to OP in color, no metal shavings.
Front diff and t-case were honey gold still.
I did not send the rear oil out for analysis but judging by the color alone, it needed to be changed. I would not say my truck sees severe usage but there are months at a time I am in 4WD or on dirt. Another note, I have no breather extension on the rear, had a few deeper crossings but noticed no water contamination when draining.
08-26-2022, 07:27 AM
Yes. I go 50K on both differentials and transfer case using Mobil Delvac Synthetic 75w90. 306K miles on the truck.
08-26-2022, 08:11 AM
Real Name: Ron
Real Name: Ron
This is a good reason for all new owners, whether brand new, or new to you, to check all fluid levels soon after purchase.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
08-26-2022, 09:26 AM
Real Name: Jeremy
Real Name: Jeremy
Good info. Just hit 35K on my 2018 and this is on my to do list. Been getting reminders from the dealership to do all 3 and an injector service for a total of $500..I think I'll be doing it myself..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
08-26-2022, 09:53 AM
on my 17 TRDP, i did both front and rear diffs at 15k miles, now just about at 45k miles and will both diffs, transfer case and trans now.
brake fluid i also do every 2 years regardless of miles
but one other fluid people always for get about is doing the power steering fluid which gets very dirty and is overlooked. Valvoline MAXLIFE atf is a good choice for PS fluid
08-31-2022, 01:44 PM
Nice.
I'm a big fan of changing the diff and trans fluids more often than recommended. I like Amsoil in the diffs, but have used Valvoline in my SxS and it's made that rattling drivetrain nice and quiet.
2022 4Runner TRD Off Road Premium, Front Bilstein 5100’s/Rear Rancho RS9000x, RCI Skid Plate, Goodyear Duratracs.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
