Old 08-27-2022, 11:34 AM #1
VA_Runna VA_Runna is offline
VA_Runna is on a distinguished road
Anyone change an upstream O2 sensor on drivers side? Code P0151
This thing looks like a bear to get to and remove. Ive seen some 3rd and 4th gen threads, but no 5th. Nothing on Youtube either. Anyone done this before?
VA_Runna is offline   Reply With QuoteReply With Quote
Old 08-27-2022, 12:38 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I've changed 3 on my Tundra. Pretty easy if you have an O2 sensor socket. It has a cutout to accommodate the wires. Spraying a little penetrant makes removal easier. Make sure the replacement has the connector - some require you to splice the wires. I use a little anti-seize on the threads to make eventual removal easier. I have heard you can extend the life of your sensor by removing it and using a torch to heat the end and burn away the residue that may be causing the fault. I haven't tried this though. I have just used a code reader to erase the code and it works for a while. I have one now that's acting up. I erased the code a couple of months ago and it hasn't come back yet. However, I don't drive that much now being retired. As far as clearance goes - you might have to get creative and try a 6pt box wrench or something.
Old 08-27-2022, 02:01 PM #3
Thanks. Did do it completely from the bottom?
Old 08-27-2022, 05:43 PM #4
flyrv9's Avatar
flyrv9's Avatar
Yes, I did all mine from below; after letting things cool off, much more room. On the Tundra I didn't have to raise the vehicle. My 2013 4Runner is a little closer to the ground; so I would probably raise it up some. Also, be kind to the connector - it's probably dirty and might not want to come apart easily.
Old 02-26-2024, 02:44 PM #5
Mestalbaum Mestalbaum is offline
Mestalbaum is on a distinguished road
Did you ever successfully get your upstream o2 sensors out? I have a 2011 and they seem impossible to remove without some serious part removal. I cant figure it out. TIA
Mike
Mestalbaum is offline   Reply With QuoteReply With Quote
3rd , 4th , 5th , gen , threads
2005 V6 Passenger Side Upstream O2 sensor replacement newsithlord 4th Gen T4Rs 4 05-27-2020 06:47 PM
Digital Temp Dial On Drivers Side Won't Change FWP 5th gen T4Rs 0 04-07-2019 10:15 PM
MAF sensor relearn? MAF code after 02 sensor change shahsmerdis 4th Gen T4Rs 7 08-30-2018 03:56 PM
Removing the drivers side 1st O2/AF sensor??? wvuviv30 4th Gen T4Rs 4 11-24-2013 08:45 PM
4th gen speed sensor harness (drivers side) tjhaf2007 For Sale: T4R Items 4 06-15-2013 10:31 AM
