08-29-2022, 05:19 AM
Body panels aerodynamics
Does anyone know if the body panels (front fascia, rockers, rear bumper) create more or less drag between SR5 versus the Limited/Sport styles? The latter hangs a bit lower. Disregard mudflaps.
Also, are different running boards used for the Limited/Sport trims due to the lower rocker panels?
08-29-2022, 05:38 AM
I think you bought the wrong vehicle if you care about that.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
08-29-2022, 07:42 AM
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
08-29-2022, 11:02 AM
I didn't want to say it, but can we please stick to the topic. Thanks.
08-29-2022, 11:14 AM
Correct, running boards have different clearances for limited/non limited models
08-29-2022, 12:12 PM
The taller front fascia of the limited/Sports styles probably does have more drag, but there are many more factors that come into play.
It has more area of Stagnant air. With that said, there are other things such as undertray covers, and even wheels shapes that make changes to aerodynamics.
Though the overall shape, weight, engine is already so... unaerodynamic that a front fascia difference will not make a substantial difference. Not to mention that Toyota probably already tested and modified their design that the difference in front fascia would not make a significant difference.
08-29-2022, 12:55 PM
Real Name: Micah
Real Name: Micah
I don't believe there is much difference in underbody clearance, so even if the Sr5 "looks cleaner" as an aerodynamic profile, all of the dark stuff underneath is also creating drag.
But as you point out, it's chasing very small numbers here to determine a difference. Tire width and load bars on top also make some difference, probably more so than body style.
08-29-2022, 01:06 PM
Yea I have no idea if there is much of a difference to underbody clearance, but the actual underbody coverage does change the drag coefficient drastically. If you look at the underbody of a Prius, its all pretty much covered up. Our 4runners got a whole bunch of bits hanging about without coverage...
With that said. I agree with all the other stuff.. not to mention uh.. it's probably moot to figure out the difference between the two tall riding bricks.
08-29-2022, 02:01 PM
The overwhelming majority of drag on vehicles comes from frontal area. The aerodynamic differences between the SR5 and the Limited will be insignificant.
08-29-2022, 02:13 PM
Real Name: Dave
Real Name: Dave
I’d assume EPA mileage figures for both are available online, at Toyota’s website or elsewhere. I’d check there. Or check online car magazine test figures for their real world results.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
08-29-2022, 04:47 PM
I doubt there is much difference, but I would say the Limited is probably better. There is a reason that the less off road oriented Tacos (and most pickups) have a front air dam. Having something smooth for air to interface with is better than the irregular surface of the skid plate and whatever else is down there. Having a rock interface with that smooth bumper is not ideal which is why the off roadish models trade aerodynamics in favor of approach angle.
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
08-29-2022, 05:01 PM
This question is like asking Ferrari owners which model is better to go offroading with...
2015 Magnetic Gray SR5P
08-29-2022, 06:09 PM
I think we are sticking to the topic. If you think a little cosmetic bumper trim is going to make a difference on a wholly inefficient car design you are kidding yourself. Fuel efficiency will never be a strong suit of this platform.
08-29-2022, 08:39 PM
Real Name: John
Real Name: John
AWD limited would get a bit worse mpg. Because of the AWD all the time, I doubt the body panels make much difference.
09-01-2022, 08:00 AM
I never looked at it this way but full set of CBI Skid Plates reduces drag underside by creating flat surface under there. I wonder if it creates downforce? On the other hand this is 5,000 pounds plus vehicle, no need for additional downforce. I hope this is not far off your topic, gcon22.
