Old 08-22-2022, 04:43 PM #1
RoadWarrior's Avatar
RoadWarrior RoadWarrior is offline
RoadWarrior is on a distinguished road
Time for a Battery Toyota TrueStart any good?
So I currently have an interstate battery going on 5 years, I've heard the Toyota TrueStarts are also made by the same folks that make interstate batteries. Does anyone have experience with these batteries? any insight would help me make a decision, I live in Texas and daily my 4R
2007 Black Sports 2wd Sold
2015 SR5P Magnetic Grey 4x4 Current
RoadWarrior is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 05:04 PM #2
rdruss's Avatar
rdruss rdruss is online now
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I only use True Starts. Have been very good IMO, last 5 years+. Never had one fail prematurely. Have '03 4Runner, '07 Highlander, had "07 Matrix.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
rdruss is online now   Reply With QuoteReply With Quote
Old 08-22-2022, 05:06 PM #3
bglfgd bglfgd is offline
bglfgd is on a distinguished road
Not in a 4R, but my wife's Camry has had one of those for almost 5 years, it's been fine FWIW.
Sent from my SM-G998U using Tapatalk
bglfgd is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 07:06 PM #4
Salvo Jimmy's Avatar
Salvo Jimmy Salvo Jimmy is offline
Real Name: Ted A Hamilton
Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough Salvo Jimmy is a jewel in the rough
I have used them in my T4Rs over the years and never had a problem.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Salvo Jimmy is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 12:49 PM #5
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
4+ yrs and not one issue. Just replaced it as a precaution 2 months ago.
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 01:33 PM #6
4Rums 4Rums is offline
4Rums will become famous soon enough
Good timing of this topic. My Interstate battery is also 5 years old and I'm contemplating preemptively replacing it at the onset of winter as I do a lot of driving and park outside in colder temps. I had not considered the TrueStart batteries as they only had one option in the 24F OEM group size (5th gen) with a lower CCA rating (575) compared to what you could get with other aftermarket options. However, there appears to be a newer 24F EFB (Enhanced Flooded Battery) with a higher 750 CCA rating (Toyota part number 00544-24FEF-TS). Any thoughts or concerns with this newer TrueStart 24F EFB battery as compared to the standard flooded TrueStart 24F or other aftermarket AGMs?
TrueStart Batteries catalog: https://www.toyotapartsandservice.com/wp-content/uploads/2021/08/03_Batteries2021_hi.pdf
Time for a Battery Toyota TrueStart any good?-truestartbatteries-jpg
4Rums is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 07:32 AM #7
I just checked my New Toyota True start Battery voltage without the car running and its showing 12.3, Shouldn't a new battery be reading around 12.6? I'm worried that's a bit to low, Should I return the battery to the dealership or am I being paranoid
Old 09-01-2022, 07:35 AM #8
osugsxr osugsxr is offline
yes return it !!!
Old 09-01-2022, 08:57 AM #9
Ok I'm at the dealership and the associate was trying to tell me 12.0 when the battery is off is normal, I told him it should be at 12.6 when the battery is off. He's having them test it said it will be around a 2 hour test and if it's reading bad they'll replace it. I litterly bought this a few days ago... anyway. Well see what happens.. I marked the battery with a pen so I can tell if they replace it or not if it comes to that..
batteries , battery , interstate , make , toyota
What should I look for diagnotic tests (battery good, ignition good, no start sounds) foo 3rd gen T4Rs 6 08-12-2015 06:28 PM
What are Good Tips and Precautions changing a 07 Toyota 4 runner battery? jow 4th Gen T4Rs 12 12-07-2012 10:02 AM
Battery Time!! THe original battery in my 04 is getting a little slow... Jeff T 4th Gen T4Rs 38 12-22-2011 10:04 PM
Time to replace shocks/struts. Good time to lift? atalarico 3rd gen T4Rs 0 06-24-2011 09:50 PM
