Old 08-30-2022, 10:06 AM #1
4RExplorer 4RExplorer is offline
Real Name: Ted
4RExplorer is on a distinguished road
Real Name: Ted
Temperature of alternator housing
I installed a temperature sensor on the top front mounting bolt of the alternator. The wire goes through a small grommet in the firewall to an LED display on the dash, just below the air conditioner knobs.
On a sunny 90 degree F day, the alternator housing hit 175 degrees F after 15 minutes of driving around.
Temperature of alternator housing-temperature-sensor-alternator-mounting-bolt-jpg  Temperature of alternator housing-temperature-sensor-wire-through-firewall-jpg  Temperature of alternator housing-temperature-alternator-led-display-jpg
2019 4Runner TRD Off Road
4RExplorer is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 05:49 PM #2
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
Interesting. I'm curious why you did this?
You are possibly the only point of data on record for that measurement.
nglayton is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 06:20 PM #3
Real Name: Ted
Real Name: Ted
I could not find any post about the alternator temperature under normal operation. The best I could find was that the engine block is somewhere in the 200 to 220 degree F range.
I will be charging an auxiliary LiFePO4 battery using a RedArc BCDC1240D, which pulls around 40A from the alternator (via the starter battery). Instead of getting a high-output alternator (Nations Starter and Alternator makes the 270XP, but not for the 2019 model year, which I have), I will be using Toyota's OEM alternator. The concern is that the alternator will overheat from the extra load from the RedArc charger. The temperature sensor will let me know if that is about to happen. Then I can turn off the charger using the "Charge LiFePO4" switch that I installed next to the temperature sensor LED display (replacing the OEM USB ports). That switch will operate a relay that sends or blocks power to the RedArc charger. When the alternator cools off a bit, I can push the switch again to resume charging.
Old 08-31-2022, 10:25 PM #4
nglayton's Avatar
Real Name: Neal
nglayton's Avatar
Real Name: Neal
Have you called them? It was my understanding that they do make one that will fit the 2019.
Old 09-01-2022, 02:38 PM #5
Real Name: Ted
Real Name: Ted
Thanks for the tip. Last I talked to them (a year or so ago?), they did not have one. But I just called, and they said they have both a 180A and 270A alternator for the 4.0 liter 2019 4Runner. They just have to update their website to show they are in stock and ready to go, but they can take orders over the phone.
Old 04-21-2023, 11:12 AM #6
scfw0x0f scfw0x0f is offline
scfw0x0f is on a distinguished road
It appears Nations sources it from DC Power; if you look at the photos on the Nations site, you can see the "DC POWER ENGINEERING" text on the front of their product.
There appear to be some differences: Nations offers powder coating options, and the positive stud appears to be plated, or maybe stainless, not plain copper. Nations also offers a 5 year warranty for $100.
DC Power has recently released this alternator for up through at least 2021 4Runners.
Temperature of alternator housing-nations-alternator-jpg
scfw0x0f is offline   Reply With QuoteReply With Quote
Old 04-22-2023, 12:32 AM #7
lewdog998's Avatar
lewdog998 lewdog998 is online now
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
That's awesome...you could use that thermometer in a back country medical situation...just make sure the lead is long enough and you could use it as a rectal thermometer
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is online now   Reply With QuoteReply With Quote
Old 04-29-2023, 05:18 PM #8
Real Name: Ted
Real Name: Ted
During winter and Spring, the alternator temperature was generally 70 to 90 degrees F above ambient temperature. But it got to 110 degrees above ambient in a recent highway traffic jam, stop and go for 20 minutes, when it was about 55 degrees outside.
Old 04-30-2023, 11:42 AM #9
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
There have been times when I thought my alternator housing seemed unusually hot but, I never checked the temp and never did anything about it. The windings even looked like they may be burned a little too. I also never had any alternator problems either.
I think you may be chasing ghosts. If the alternator dies and the replacement dies prematurely, it may be time to take a hard look at what is going on.
Everybody needs a hobby, a deep dive into the 4 Runner electrical system is not a bad one either. There is surely knowledge to be gained.
Now I'm curious. I'll warm mine up and check the housing temp with a temp gun or thermocouple and report back.
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 04-30-2023, 05:51 PM #10
After letting my 4 Runner warm up completely and driving around some. I left my refrigerator on most of the day so my aux battery was charging 15-17 amps, with AC on and 90 degree weather, my alternator case was at 190 degrees. Seems pretty hot.
2007 FJ
Old 04-30-2023, 06:22 PM #11
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Since the alternator is bolted directly to the engine it only make sense it will be about the same temperature as the running engine....which is around 185 to 190 degrees and as such is designed to operate at that temperature, so I don't understand what the big deal is!!
2004 Limited V8
Old 05-01-2023, 11:51 AM #12
Real Name: Ted
Real Name: Ted
100 degrees above ambient temperature, with the extra load of 15-17 amps from the aux battery charger, seems reasonable, since I'm finding 70 to 90 degrees (and once, during a traffic jam, 110 degrees) above ambient when there were no non-Toyota loads. I haven't measured the alternator temperature on a really hot summer day yet.
If the alternator dies from normal wear and tear, that's fine, I'll get a new one, maybe the DC Power 270 XP. I just don't want to kill it prematurely from overheating because I'm charging the auxiliary battery when the alternator is already too hot.
Old 07-13-2023, 07:26 PM #13
Real Name: Ted
Real Name: Ted
After changing the oil, the alternator is typically measuring around 60 to 70 degrees above ambient temperature instead of 70 to 90 degrees. I like that it's running cooler.
Old 07-13-2023, 08:20 PM #14
Real Name: Skip
Real Name: Skip
Can you post a link to the temperature sensor and read out you have?
2004 Limited V8
Old 07-18-2023, 03:17 PM #15
Real Name: Ted
Real Name: Ted
This is the temperature sensor and digital readout display:
CHT Digital PMD1XT Pryometer Gauge + CHT Cylinder Head Temperature Sensor Kit FS
Options:
(1) 0 to 5 VCD Analog Output. I got this option to automate the charging based on the alternator temperature, but ended up not using it. While charging, I just look at the temperature display every once in awhile, and manually turn the charger off if the temperature gets too high. I also manually feel the RedArc charger (installed within reach behind the front passenger seat) while driving and charging, and manually turn it off when it gets too hot to touch.
(2) Protective Aluminum Enclosure Housing. Not necessary if installing in a DIY cutout in the lower dashboard with a simple piece of aluminum plate that I had lying around. The housing might be useful if installing on top of the dashboard.
(3) Audible Alarm. Your choice.
(4) A 10mm inner diameter ring terminal fits the front alternator mounting bolt.
A few installation notes:
Once the sensor is secured under the alternator mounting bolt, I bent the shaft of the sensor slightly to avoid hitting the underside of the 4Runner hood. The sensor wire went through the rubber grommet in the firewall on the driver's side. I did this by duct taping the ends of the wires from the sensor to a piece of coat hangar wire, then pushing the coat hangar wire through the grommet, then pulling it out from the driver's side footwell inside the vehicle.
In my installation, the LED temperature display is set just above the tiny rectangular cubby in front of the gear shift knob. The DIY metal plate has a rectangular cutout that just fits the LED temperature display, but is large enough to enable screwing to the OEM plastic cubby surround.
On the back of the LED temperature display, Terminal #7 goes to the power wire from the temperature sensor (on mine, a yellow wire). Terminal #6 goes to the ground wire from the temperature sensor (on mine, a red wire). Terminal #1 goes to the pigtail from the Add-a-Circuit in the 12V fuse block in the driver's side front footwell. That Add-a-Circuit is in one of the ignition-switched fuse positions that has power only when the vehicle is turned on, to prevent draining the starter battery if the "Charge LiFePO4" button is accidentally left on. Finally, Terminal #2 goes to ground.
air , alternator , conditioner , housing , temperature
A/T oil temperature light: what temperature? NJ-4Runner 3rd gen T4Rs 21 05-06-2021 12:36 PM
Odd temperature... should I be worried bay_area4runner 3rd gen T4Rs 13 05-26-2017 12:27 PM
outside temperature Limited2K 3rd gen T4Rs 8 01-14-2011 01:53 PM
Outside temperature not available mcflavin 4th Gen T4Rs 10 01-08-2011 10:47 PM
Outside Air Temperature firsttoyo 3rd gen T4Rs 15 12-27-2009 04:35 PM
