08-30-2022, 11:45 PM
what's wrong?
2022 4runner with 4K miles, On a a 400 drive today, I stopped for gas after driving 3+ hours using the cruise control, Drove a mile back to the HWY and I got 3 system malfunction warnings: Anti-lock brake, Pre-Collision,& Cruise Control System Malfunction warnings. The odometer said to call dealer, so they said to bring it in tomorrow.The truck rode/sounded fine. I got within 10 miles from home and the car died out and wouldnt restart, NOTHING. No cranking. I couldnt even shift out of Park. Had it towed to the dealer. They havent looked at it yet, but the service writer said it sounds like rodents chewed some wires. It was parked for 2 days outside where there are chipmunks, so I guess its possible. I had a 2004 with 250K and I never had it towed. Never died out, never failed to start. Super bummed
08-31-2022, 01:55 AM
gas cap.....
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS sway bar controller
08-31-2022, 08:01 AM
Real Name: Ron
Real Name: Ron
Keep us posted! We want to know no matter how simple or weird it is.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
08-31-2022, 10:58 AM
Service dept just called, it is supposed to be a faulty brake sensor switch that apparently is on the same warning circuit as the other malfunction warnings. Also causes related issues with shifting out of Park and starting with keyless start button.
08-31-2022, 11:35 AM
Really? how would a gas cap cause shifting out of P and starting issues? I didnt say Check Engine light
08-31-2022, 10:25 PM
I had the same beginning symptoms 3 system malfunction warnings: Anti-lock brake, Pre-Collision,& Cruise Control System Malfunction warnings in my 2021 Pro. There was no real change in the way it drove or felt so I took about a 20 minutes drive directly to the dealership. They said it was a stuck evap. valve that had resolved itself on the way there. They wanted me to bring it back if I had any more problems. I have put 20,00 miles on it with no issues since then.
08-31-2022, 11:28 PM
you be surprised the dumb sh1t that happens if the gas cap is clicked too many times.
09-01-2022, 05:30 AM
Real Name: Ted A Hamilton
Or not clicked enough
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
