Old 09-02-2022, 11:46 PM #16
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by NeilYoung View Post
I appreciate the advice coming from someone who has some first hand experience with "streamers off the lake". I'm just 30 miles north of you on the other side of the wall. The SS3's (Sports) are on my Christmas wish list. I just got sucked into believing the reviews (including some on this forum) that some yellow drop in bulbs are a viable, cost effective alternative to specifically engineered spots. I guess the moral of the story is spend once, cry once.
SS3's aren't any better than the lasfit pods. I run ss3 and ss2 and lasfit pods currently. They are very similar in performance, but i wouldn't say one is better than the other. Get the lights that fit your budget and your needs.
Old 09-04-2022, 10:56 AM #17
Predatorsniper2005 Predatorsniper2005 is offline
Predatorsniper2005 is on a distinguished road
Lasfit 22" Upper Grille Light Bar Pics
Pics of Lasfit 22 Upper Grille Light Bar
Lasfit 22" Amber Light Bar - Upper Grill Mount-drivers-side-lb-jpg  Lasfit 22" Amber Light Bar - Upper Grill Mount-front-lb-upper-grille-jpg  Lasfit 22" Amber Light Bar - Upper Grill Mount-field-lb-only-jpg  Lasfit 22" Amber Light Bar - Upper Grill Mount-dirt-road-lb-only-jpg
Predatorsniper2005 is offline   Reply With QuoteReply With Quote
Old 09-04-2022, 12:49 PM #18
mrblah's Avatar
mrblah's Avatar
Thanks ! I did a quick dark garage test and while the bottom bracket hole allows you to reinstall the centre/latch support, the lightbar is no longer vertically centred in the top grill and the bottom of the hotspot gets cut off. Ideally, a good set of fogs should fill the gap but my crappy, overly inflated lumen, fogs bulbs are just not up to the challenge. I ended up back at the top hole for my use case but it's good to have options.
That makes sense I have decent fog lights so I never noticed the cutoff you talked about that is caused by the lower grill portion. Good to know
Old 09-04-2022, 10:59 PM #19
Originally Posted by mrblah View Post
just to add to his review:
Universal wiring is typically shiet, unless it’s vehicle and application specific. I’ve spent a lot of money on wiring harnesses only to cut them up to the point where I should have made my own harness to begin with.
You won't get great cutoff because its sitting behind the mesh grill, and its designed to be mainly as a spot light. So OP can probably aim it higher to get rid of that giant hot spot.
You also can get the hood latch / radiator support back on. I don't remember if i used the top hole or bottom hole on the mounting bracket to do so. I was still able to aim the lightbar also. So it is very possible.
Just fyi.
this. I keep the relays and thats about it lol. the dinky switches are repurposed as toys for the boys lol.
Old 09-04-2022, 11:57 PM #20
mrblah's Avatar
mrblah's Avatar
lol dont forget about the DT connectors too... lol
did u get my PM on the security thing a bob.
Old 09-05-2022, 09:55 AM #21
lol exactly. and yes
amber , bar , beams , lasfit , light
Lasfit 42" Amber Light Bar Roof Mount Testing Invitation lasfit 5th gen T4Rs 13 09-08-2022 12:36 AM
New Arrivals!🔥Lasfit Amber Light Bars Pre-Launches👉 lasfit LASFIT 0 08-05-2022 12:44 PM
【51】IMPROVED [LASFIT] Switchback Turn Signal Light MOD. Cool White & Amber youngwas 5th gen T4Rs 10 07-07-2021 02:21 PM
【52】3x Brighter Rear LED Turn Signal Light MOD [LASFIT]. Amber youngwas 5th gen T4Rs 12 12-11-2020 10:48 PM
