Old 09-02-2022, 01:19 PM #16
RobS10's Avatar
RobS10 RobS10 is offline
RobS10 has a spectacular aura about RobS10 has a spectacular aura about
RobS10's Avatar
Originally Posted by 02SE View Post
Yep. It just lacks power in the RPM range where the engine is running when in 5th gear at highway speed. So you get a downshift or two to bring the engine up into the RPM range where it does make enough power to maintain speed on grades, strong headwinds, etc.
Of course there might also be a point where the engine might not make enough power to maintain speed no matter what gear the transmission is in. Then you're just going to be going slower until the road grade decreases, or conditions improve.
There are vehicles with a better power-to-weight ratio than the 4Runner. Especially when a 4Runner is modified with a lift, bigger tires, and all sorts of other accessories, as so many of us do.
You can add power to increase the power-to-weight ratio. The biggest improvement would be to use forced induction. Ether a supercharger, or turbocharger. But they aren't cheap, and you'll want to use premium fuel (which is an ongoing expense) to avoid pre-ignition.
I have other vehicles with much better power-to-weight ratios. They fill a want/need just like the relatively slow and underpowered 4Runner.
For me the 4Runner is adequate at stock power levels. But I don't put heavy demands on it, or expect more than it's capable of, either.
We have been driving a '99 SR5 for 17 years now and used to the lack of power on hills problem with the cruise control, but was surprised I could drive our new ORP on hills much easier, without the double downshifts, and at the same speed, than with the cruise control.
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
RobS10 is offline   Reply With QuoteReply With Quote
Old 09-02-2022, 01:24 PM #17
JoshDub JoshDub is online now
JoshDub is on a distinguished road
It's not just that the 4runner has to downshift, it hunts. It'll go from 5 > 4 >3 > 4 > 3 > 4 > 3 and so on continuously until it gets to a level grade. shifting every couple seconds. While the lack of power is a root of the problem, the primary issue is awful programming on Toyota's behalf. This happens on grades that do not require downshifting at all, just mildly more throttle.
JoshDub is online now   Reply With QuoteReply With Quote
Old 09-02-2022, 01:36 PM #18
RobS10's Avatar
RobS10's Avatar
Exactly, that's just what it feels like, a Programming issue, as our old 4Runner doesn't seem to have such erratic behavior as the new more "advanced" one!
Old 09-02-2022, 02:04 PM #19
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
The new one also has another gear to choose from, that your old '99 with it's A340 4-speed didn't. The old 4-speed would inherently hunt less.
I've driven numerous modern rental cars with relatively underpowered at low RPM engines, mated to 8+ gear transmissions. They are shifting all the time in situations where the 5th gen 4Runner also does.
Underpowered cars with CVT transmissions are also changing ratios constantly in those situations.
They try to keep the RPM as low as possible when cruising on flat ground, to maximize MPG. But that just means that anything demanding more power might need a downshift or two.
It's just the way it is with relatively low-powered vehicles, with the goal being maximum MPG.
02SE is offline   Reply With QuoteReply With Quote
Old 09-02-2022, 06:32 PM #20
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I run in S5 all the time, it helps with downshifts and delays. But that's on my old 2013 TE.
Our other Toyota is a 2018 Sienna with the 8 speed and radar cruise. The radar cruise works very well in most conditions.
Impression of Radar Cruise Control on 2020 ORP-toyotas2-jpg
BobsTrail is offline   Reply With QuoteReply With Quote
Old 09-02-2022, 07:08 PM #21
RobS10's Avatar
RobS10's Avatar
Interesting...I'll have to give that a try. I assumed that S5 and Drive were the same as far as RPM/Load, but maybe there is a difference in how the computer is programmed?
control , cruise , engine , hill , radar
Dynamic Radar Cruise Control / Vehicle-to-Vehicle Distance Control Mode / PCS hunthorde General Discussions 2 03-16-2023 09:46 AM
Bull Bar + Dynamic Radar Cruise Control / Distance Control Mode / PCS hunthorde 5th gen T4Rs 1 04-29-2021 11:09 AM
2020 Adaptive Cruise Control (ACC) Review Adi4runner 5th gen T4Rs 9 09-11-2020 12:09 PM
2020 TRD PRO - Cruise Control not working deevilla7 5th gen T4Rs 10 04-22-2020 05:28 PM
Question on 2019 and 2020 cruise control. Sky 5th gen T4Rs 15 11-28-2019 09:51 AM
