Old 09-02-2022, 11:08 PM #1
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
Driver side A pillar wiring harness
Hey everybody,
Trying to get this stupid wiring harness open to install a breakout harness in between the connectors but I cannot for the life of me figure out how to separate this thing… anyone ever get this dang plug released?
*installing a Vled footwell lighting kit. This is what the instructions show for this step (& no it is not as easy as simply placing your finger on the plug as referenced in the photo…there is no catch to release where they are pointing):
Driver side A pillar wiring harness-34a37352-ece1-429a-bbb7-89273a0fdb90-jpg
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 04-09-2023, 02:58 PM #2
robkh1984 robkh1984 is offline
robkh1984 is on a distinguished road
Ran into the same issue. Ended up demolishing one of them to get the connector out. Looking for advice before I tackle the one on the passenger side.
robkh1984 is offline   Reply With QuoteReply With Quote
Old 04-10-2023, 11:01 PM #3
Sarge61 Sarge61 is offline
Sarge61 is on a distinguished road
Be advised that the instructions are not talking about separating the connector. It's referring to removing the connector from the A pillar holder which is probably a "pin-through-hole" mount. squeeze the pin and push it back through the hole. This should allow you to pull the connector away from the pillar slightly and give you more room to separate the wired connectors.
Sarge61 is offline   Reply With QuoteReply With Quote
Old 04-12-2023, 12:24 PM #4
Which pin would we squeeze? I've taken both wiring harnesses off of that clip. It looks the handess has a clip inside the A-Pillar that's extended like a V. There's no way of getting a tool (picker?) in there to squeeze one side in without pulling the connector.
Any tips?
Old 04-13-2023, 05:26 PM #5
So do I understand you correctly that you removed the mated connectors from the pillar mount and you still can't get the connectors apart?
Old 04-17-2023, 02:41 AM #6
Correct. Difficult to pry the connector harness from the A-Pillar frame once the two connectors are disconnected. Any tips to help pull out the harness?
harness , kit , lighting , plug , wiring
WTB Driver side A Pillar trim for a 3rd gen Proto12 Want to Buy/Trade 0 12-02-2021 11:37 AM
LH/Driver side wiring harness HELP Tielur 4th Gen T4Rs 1 03-19-2020 08:24 PM
Front Driver side A-pillar Grab handle? Brad2064 5th gen T4Rs 22 05-29-2019 01:14 PM
Driver side a-pillar grab handle? dedonderosa 5th gen T4Rs 30 05-04-2019 02:10 AM
Removing driver side a pillar GettinOld 5th gen T4Rs 0 03-06-2013 02:30 PM
