Originally Posted by Hammer0313
There is a seal swelling product called AT-205 that you can add to the engine oil, it really does work very well. Only thing is you need to put a bottle in with every oil change.
Thanks Hammer
I think this may be a better solution. The engine only has about 30,000 miles and even though it is a rebuild, I’m not sure if using high mileage oil was the best option.
At this point it’s a minor leak that I don’t think is even leaving a puddle. It seems to occur only when driving. So if a additive will stop the leak then that will be the best option.
