Old 09-04-2022, 09:01 PM #1
Offroad Architect's Avatar
Offroad Architect Offroad Architect is offline
Offroad Architect is on a distinguished road
What is the best Circlip setting for Bilstein 6112 Coilovers?
Hey all,
My rig is a non-KDSS 2015 TRD Pro with the upgraded Toyota tuned TRD Pro Bilstein suspension system. Its past time for me to replace the front coil-overs and I am looking at going with the Bilstein 6112's for now. I also have a body mount chop and I roll on 295 70R17's. I've had no problems with the wheels. Basically I want to just match what I have in terms of ride height and suspension lift.
I have looked at ordering the 6112's online and the circlip options one has to select when ordering the coil-overs are as follows:
#6 / #4 = 2.6"
#5 / #3 = 2.2"
#4 / #2 = 1.9"
#3 / #1 = 1.5"
Everything that I have found states that the original TRD-tuned Bilstein's provided 2.5 in lift in the front. So, I am assuming that I should select the 2.6" circlip location for the 6112's. I am looking for some community confirmation on this. What I am afraid of is selecting the 2.6" and then once I put them on my rig, the front end will sit too high compared to what it has been prior.
Can anyone provide some insight on which height selection for the 6112's is the best to match the original TRD tuned settings?
Thank you!
Offroad Architect is offline   Reply With QuoteReply With Quote
Old 09-04-2022, 10:04 PM #2
Saker's Avatar
Saker Saker is online now
Saker's Avatar
Originally Posted by Offroad Architect View Post
Hey all,
#6 / #4 = 2.6"
#5 / #3 = 2.2"
#4 / #2 = 1.9"
#3 / #1 = 1.5"
Thank you!
Hate to inform you, but you misread the shock diameter of the TRD Bilstein Pro set up for the height!
SEE: Toyota 4Runner Trd pro bilstein shocks with trd-tuned front springs. Suspension kit - PTR1389160 - Genuine Toyota Accessory
The Diameter of the shocks up front are 2.5" and rears are 2".
The fronts on the TRD Bilstein Pro set up give it a 1" lift height.
The #4 / #2 = 1.9" will give you a slight rake and should be almost level when you load the T4R....
or you could do #5 / #3 = 2.2" and place a 1" spacer over the rear coils.
Best Regards,
Saker
Saker is online now   Reply With QuoteReply With Quote
Old 09-04-2022, 10:50 PM #3
Saker,
Thank you so much for the correction and information. I feel pretty silly making that mistake. But, that's exactly the kind of warm and fuzzy I was hoping for.
Cheer and happy trails!
Old 09-04-2022, 10:56 PM #4
i tried out a middle'ish setting. eventually just set them to the top setting. loved them, especially for the money.
Old 09-05-2022, 07:08 AM #5
grizz1925 grizz1925 is offline
grizz1925 is on a distinguished road
I just purchased this set up as well, although I stayed with 265s for now. I would double check those clip locations for lift setting. I went through shock surplus and saw there circlip recommendations were all over the place. I ultimately narrowed down and confirmed with them these were the right ones for non KDSS and non heavy load:
#7 / #5
2.5"
#6 / #4
2"
#5 / #3
1.6"
#4 / #2
1.2"
#3 / #1
0.8"
grizz1925 is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 05:25 PM #6
dedonderosa dedonderosa is offline
dedonderosa will become famous soon enough
if you want to keep the height about the same as the stock trd pro suspension, you could always take the old Bilstein factory shock and match it up next to the new one to see where you want the spring to sit and select that circlip location which i think will be #4/#2 location. thats what i think im going to do when i replace my suspension down the road. what i found out is the springs that come with the 6112s are the same springs the come on the trdp made by eibach and are known for cracking. what i did cause my truck had low miles when my spring broke is i got myself a set of Dobinson C59-748R springs which adds 1 inch to the trdp model making it a total of 2 inches compared to a base 4runner.
dedonderosa is offline   Reply With QuoteReply With Quote
6112s , bilstein , circlip , front , trd
FS Bilstein 6112 Coilovers w/B12 Spring, $500, Alexandria, VA 21StealthRnr For Sale: Suspension/Wheels/Tires 3 01-11-2022 09:01 AM
New Bilstein 6112 w/600lb springs which setting matches Highlander? Heyduke 3rd gen T4Rs 0 06-01-2020 06:05 PM
Reviews on the new Bilstein 6112 coilovers? 1985taylor1925 3rd gen T4Rs 26 01-05-2019 12:50 AM
Bilstein 6112 with King 14x3x650# - which clip setting? jasxn 5th gen T4Rs 2 03-13-2018 12:14 PM
6112 circlip lift settings different on 2wd and 4wd 4runners?? SoFloT4Run 5th gen T4Rs 1 11-25-2017 11:40 PM
