Old 01-23-2023, 05:21 PM #1
simeon simeon is offline
simeon is on a distinguished road
Has anyone noticed the Diode Dynamics SS3 Pro's make a humming sound when turned on?
I have a pair set to come on in the rear when the vehicle is in reverse, and I noticed they make a sound which seems odd.
I ran dedicated 12 gauge wire from the switch pros 9100 to it.
I have a 30 inch light bar from diode dynamics and they are silent.
Just curious if this is normal before I contact DD support about it.
Simeon
simeon is offline   Reply With QuoteReply With Quote
Old 01-23-2023, 07:55 PM #2
Bobby12many's Avatar
Bobby12many Bobby12many is offline
Bobby12many will become famous soon enough
Making an assumption here that the Switch 9100 is a "smart relay" and you arent delivering power directly off of a "switch"....
I dont have experience with these specific lights, but have dealt with dozens of different LED systems over the years. IME buzzing and/or humming almost always indicates something is amiss with the grounding or the driver. If the wiring is properly grounded/isolated/relay'd and the sound is coming from the light itself, I would suspect an issue with the driver module within the assembly.
grain of salt here, as this may very well be SOP for these lights.
Bobby12many is offline   Reply With QuoteReply With Quote
Old 01-24-2023, 12:16 PM #3
For the rear lights I am using the frame as a return ground path. Is it possible for that to cause the humming vs. a home run for the ground to the battery?
I guess my next step would be to contact diode dynamics and see what they say. Thanks for the help.
Old 01-24-2023, 04:34 PM #4
100% possible that this is a grounding issue. Just as bad grounds in an audio system cause whine and noise through your speakers, a bad ground can create noise and flickering in LED light systems.
Did you sand/wirewheel the surface of the frame before grounding to it? Is the wire securely crimped in your terminal?
All that said - some buzzing/hum may be inherent to these lights, but if its loud enough for you to question it, its worth investigating
Old 01-24-2023, 04:41 PM #5
I think the ground crimps should be fine. I will pull off the bolt on frame and grind it to make a better connection after it stops raining here. Will report back. Thanks.
diode , dynamics , make , noticed , pros
Diode Dynamics SS3 LED Fog Light SidKo 5th gen T4Rs 32 07-30-2023 01:58 PM
Diode Dynamics SS3 Fogs? spyder918 5th gen T4Rs 19 09-18-2022 06:36 AM
Diode Dynamics SS3 LED Pods mjg514 4th Gen T4Rs 3 08-22-2021 02:48 PM
Diode Dynamics HID? TheJokingExplorer 5th gen T4Rs 1 02-08-2018 10:28 PM
