Old 09-05-2022, 08:50 AM #1
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Maximizing Off-Road Reliability
My setup sees a lot of remote backcountry travel over some pretty technical terrain. Due to this I like to be on top of maintenance, carry spare parts and be preemptive on replacing critical components that are near end of life. Early November I plan on dialing it up a notch by attempting the full Rubicon Trail on a pretty moderate setup. DM me if you are interested in joining
Due to this I want to make sure my truck is in the best shape it can be. So Ill be spending the next few weeks replacing parts and ensuring maintenance is up to date. I was just curious to see what other owners have replaced either preemptively or from breakage from trail usage and what spares you all are carrying.
Here's what I have:
2012 SR5 w/167,000 miles
Trail Failures
-Outer tie rods
-Steering Rack
-Tires
Replaced Preemptively or from Trail Wear
-Lower Ball Joints / Lower Control Arms
-Inner Tie Rods
-Steering Rack
-Bushings on Aftermarket Icon UCAs
-Spherical bearings on King Coilovers
-Tires
Spare Parts I Carry
-Inner Tie Rod
-Outer Tie Rod
-CV Axle
-Rear Driveshaft (I don't carry one usually but may bring one for the Rubicon)
Things I'm Thinking of Replacing Preemptively
-Front Wheel Bearings
-Rear Wheel Bearings
-Alternator
As you can see it's not a super long list which I think is a testament to how well 5th gens are built. So T4R what say you?
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 09:23 AM #2
honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of
i brought a spare coilover and spare rear shock for mexico. it was jsut a 6112 and fox 2.0. but i figured thatd be plenty to get it roadworthy at least. otherwise i brought the same parts minus a driveshaft.
the question is how much work do you really want to do on the trail and how many tools do you want to bring. ball joints, spherical bearings, bushings can all be worn and ruined but will still function fine to get you home
Did you gusset your cam tabs yet?
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS sway bar controller
Old 09-05-2022, 11:25 AM #3
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
Here’s a few ideas:
Extra lower shock bolts, or retorque with some blue locktite. I’ve bent my front OE bolt before.
Sway bar links or extra bushings at least. I’ve blown bushings out, n the rubicon you may bend a link?
Radiator has an external trans line cooler metal pipe. If you haven’t replaced, check it as they corrode and fail without warning.
Gas tank straps can also corrode and fail. Maybe not a consideration as your in CA?
Lube the driveshafts and all universals
I’ve heard a damaged speed sensor or wiring near the wheel can stop use of the electronics like abs, Atrac, crawl control, etc. So maybe spares of front and rear sensors or wiring if damaged? Low probability but a bummer.
The lower serp belt pulley usually fails first, replace or bring a spair? Probably not gonna stop working but could slowly cause a belt problem or just a lot of noise. Which will wear you out faster.
Find a shop on your route to get an oil change at 5k, maybe even rear diff depending on how hard your working it?
Change the coolant, pull the fan shroud and look for side tank leaks of pickish crust.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 07:40 PM #4
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
I think drivetrain-wise, you’ve covered all the big issues. My recommendations for necessary equipment to avoid drivetrain failures:
Armor -
Engine
Tcase
Sliders
Lower rear link armor
Armored/DOM lower links with stock as spares
Armored shock mounts
Weld on Rear diff armor
Reinforced or upgraded gas tank armor
Front and rear traction device
Front eaton or ARB
Rear eaton or ARB
Here's what I have:
Trail Failures
-Outer tie rods
-Steering Rack
-Tires
-Inner Tie Rods
-Steering Rack
-Tires
Spare Parts I Carry
-Inner Tie Rod
-Outer Tie Rod
-CV Axle
-Alternator
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 09-06-2022, 08:45 AM #5
Xtremluck's Avatar
Xtremluck's Avatar
That is a good call. It would be nice to have spare suspension components.
I haven't gusseted my cam tabs yet and I'm suffering because of it. I just about knock my alignment out every 2nd or 3rd trip these days. So it's definitely on the list of things to do.
Old 09-06-2022, 08:58 AM #6
Xtremluck's Avatar
Xtremluck's Avatar
Armor -
Engine
Tcase
Sliders
Front eaton or ARB
Rear eaton or ARB
Yup fully armored except for rear shock mounts, rear diff and lower rear links. All places that have already gotten hammered. I was thinking about armoring up the rear diff since I drag it so much but I'm not so hot about the lost clearance. Sometimes millimeters count when it comes to clearing something or having to pull winch line to drag myself across things.
I have my eye on a front locker (Already have an Eaton rear) but that definitely won't make it for this trip. I'm also a bit concerned about the durability of our front axle in low traction situations with a locker up there. Supposedly the CV axles will be the fuse that breaks before anything in the diff implodes but who knows. I recently saw a 5th gen grenade his axle with light throttle while locked. Although he was on 37s and had upgraded CV axles which probably transferred the breaking point to his diff/
Old 09-06-2022, 10:13 AM #7
100% agree. I absolutely waffle on the the front locker. I've seen ATRAC be very capable, but a fully locked diff provides SO much more traction, but at the cost of stress on components. (flip flop, flip flop goes my opinion..lol)
I would say that 34-35's locked would by my upper limit personally, as far as durability on our front end/CV's. I don't like the idea of aftermarket CV's, since as you say, they move the fuse to somewhere else. I'd rather carry 3-4 CV's and the kit to swap them out than deal with a busted ring gear or driveshaft yoke, or something like that.
As far as the Rubicon trail goes. Everyone I've talked to who goes, tells me that 35's are the minimum, in their opinion. Have to say that while I agree 35's are probably better - again there's that balance. I think I'd rather have a 100% durable, armored truck that I have to drag a bit over the trail than a truck on 35's/37's that is at the limit of durability front-end wise. I have no doubt that the rear-end can handle 35's-37's, so maybe it's a choice:
A. 33's, fully locked, fully armored and prepared to drag and winch as needed. I think 33's wouldn't stress out CV's very much at all, with conservative driving - maybe plan on 4 days on the trail to provide time needed/rest from long trail days.
B. 35's, open front/locked rear, fully armored with less traction, but less drag and less chance of busting a front-end component.
Old 09-06-2022, 10:37 AM #8
Agreed - i was talking more about the weld-on cap that protects the metal next to the ring gear.. I think TrailGear sells them.
Not only do you lose ground clearance with the that bolt-on "shovel" diff skid type, I've seen a vid that showed the skid come loose and start grinding on the driveshaft area, where it wasn't in any danger of damage with a good drive who keeps rocks away from there.
That's a big "nope" for me, personally.
Here's the vid, @ the 12:36 mark - also take note of the lower shock skids. They look well used. :
Old 09-06-2022, 04:18 PM #9
shock skids with bolt protection are a must (fj toyman ones rock). just by running dirt roads at high speeds the bolts turn to ovals from rock spray
Old 09-06-2022, 08:43 PM #10
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
I'd go to Taco Tab kit and get rid of the bogus alignment adjuster cams, It makes no sense to me to run one cam forward and the other cam rearward having the LCA "cocked". Run them both forward, middle, or rear and get the final alignment adjust with SPC UCA.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 09-07-2022, 08:37 AM #11
Xtremluck's Avatar
Xtremluck's Avatar
Agreed, when I pull mine for a rebuild I will most likely have to replace the lowers. They are severely chewed up, I should have made that investment long ago.
Old 09-07-2022, 08:43 AM #12
Xtremluck's Avatar
Xtremluck's Avatar
Ouch that does look terrible, my rear axle pumpkin has been holding up the only thing I'm worried about is that drain bolt. I may add one to my trail kit just in case.
Old 09-07-2022, 08:45 AM #13
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future Inv4drZm has a brilliant future
Inv4drZm's Avatar
I would take more ground clearance over a front locker on the rubicon. So many boulders.
While its possible to make it through with 33s I wouldn't personally do it. It wouldn't be fun for me. More work winching and spotting.
Run 35s or 37s, take it easy, and carry spares. I made it through with 37s and stock CVs. I only broke my exhaust, hence why ground clearance is important.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 09-07-2022, 08:54 AM #14
Xtremluck's Avatar
Xtremluck's Avatar
You are spot on. I think there is a point where your setup is too built up and you actually start hampering the overall performance and reliability off road. Let's be honest most folks who are up on 35s are just driving around on maintained USFS roads "Overlanding". Not dragging their trucks through rock gardens that like to eat up body panels
I truly think 33" tires is the sweet spot for this platform but I'm tempted by that extra ground clearance to go just a little bigger. Right now I'm either going to go skinny 34" 285/75/17 or Baby 35" BFG K02 315/70/17 for the next round of rubber. The BFGs are pretty durable from my experience and weigh next to nothing for that size (62 lbs). Hoping that keeping the rotational mass down a bit will help with durability.
Either way for this Rubicon attempt I will be on 33s.
Old 09-07-2022, 09:09 AM #15
Xtremluck's Avatar
Xtremluck's Avatar
Thanks for the first hand insight, I agree the extra clearance will make it much more easier. I've done a small portion of the Rubicon before and some of the surrounding trails so I totally hear you about those boulders. Every mm counts for sure.
parts , preemptively , spare , tie , trail
T4R V8 reliability bo0oost 4th Gen T4Rs 35 12-31-2020 05:37 PM
How's the reliability? LUVDA4RUNNER 4th Gen T4Rs 13 10-20-2012 12:54 PM
4th gen V6 reliability vs 3rd gen? w00derson 4th Gen T4Rs 4 01-23-2012 05:38 PM
maximizing my supercharger jacobhaflich 3rd gen T4Rs 14 09-08-2011 03:57 AM
Long road trip to arctic circle, tire reliability? youkefei 5th gen T4Rs 15 06-12-2011 01:16 AM
