09-07-2022, 12:43 AM
Windshield side trim molding
Does anyone know if the side trim that goes between the windshield and the A frame area is removable? Or is this piece installed when the windshield gets installed? As in before it gets installed.
09-07-2022, 06:48 PM
I think you could yank it off if you wanted to but it's not meant to be removable. Pretty sure you'd have to have the windshield re-set to reinstall the molding.
2019 TRD ORP
09-08-2022, 02:12 AM
Kinda what I was thinking, thanks!
09-08-2022, 09:31 AM
the pieces that run up and down on the outside of the car? It comes off and goes back in place just fine. i've had mine out a few times. One side i have 2 small wires running behind it, cant even tell. driver side i have the antennae wire running behind it. That one you can tell has something behind it lol.
09-08-2022, 08:08 PM
Yes the 2 small pieces on the left and right of the windshield. I was going to pull the driver side off but I wasn’t sure if it was made to come off that way or not with the windshield in place.
09-08-2022, 10:35 PM
yea they peel off. take it easy, itll tear. I hadnt thought of this before, but some silicon spray will make reinstall super easy, especially if youre stuffing a wire behind it.
09-09-2022, 12:49 AM
Is this the piece you guys are talking about? I had to have my windshield replaced this past spring and they did a good job, but now this trim piece keeps popping out at the top corner of the windshield. I push it back in but it keeps working its way back out. Could I pull it out and put some silicone seal behind it and re seat it or should I just have the windshield company come out and replace it? I have a lifetime warranty on the work.
09-09-2022, 01:23 AM
yea i'd pop that corner out, use some black rtv and a piece of tape to hold it in place over night. its just a cover so the windshield channel/butyl is covered up and not visible.
09-09-2022, 06:59 AM
Thanks. I'll do that.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
