Old 09-07-2022, 07:35 PM #1
mrkothegigolo's Avatar
mrkothegigolo mrkothegigolo is offline
mrkothegigolo is on a distinguished road
Diode Dynamics SS3 backlight question
Sorry if this was asked already but I tried the search function and google and got nothing.
I just got the SS3 fog lights with backlight function. Is there anyway to wire the backlight function to turn on with DRLs AND headlights?
98 Limited - SOLD
22 MGM ORP
If you're gonna be dumb, you gotta be tough
mrkothegigolo is offline   Reply With QuoteReply With Quote
Old 09-07-2022, 09:11 PM #2
hoppyjr hoppyjr is online now
hoppyjr will become famous soon enough hoppyjr will become famous soon enough
Since you have a 22, I’d go a different route….and ditch the halogen DRL altogether.
I would unplug the DRL’s, then tap the SS3 backlight to them.
If desired you could add a secondary LED DRL using the same method, tapping existing DRL circuit/connectors.
Then I’d pick up a 9005 relay harness, install some quality 9005 LED bulbs into the DRL (former DRL / high beam on 21 prior) position. Trigger those using either a separate switch, accessory panel (like Switch Pros), or from a tap on existing high beam circuit.
This gets rid of the ugly halogen DRL, but maintains DRL function. It also gives you supplemental high beams, which could be very useful.
YMMV
hoppyjr is online now   Reply With QuoteReply With Quote
Old 09-07-2022, 09:24 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
I was able too but I hacked apart a Toyota relay box that isn’t financially feasible. I only did it because I already had the relay box from a old led fog light that had built in halo’s utilizing a factory switch
Old 09-07-2022, 10:20 PM #4
Holy crap I seem to have gotten in over my head. It's like you guys are speaking another language with your harnesses and relays. Lol. I hope I can figure this out with some googling
98 Limited - SOLD
22 MGM ORP
Old 09-08-2022, 01:13 AM #5
honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of
tap both power wires (drl and headlight) with the trigger wire from the DD backlight? just gotta make it get the signal from the OEM wire(s).
test light and poke the OEM wires to figure out which ones you gotta tap into. I did something similar with a headlight retrofit and demon eyes on my titan back in the day. its definitly not "plug and play" and kinda fubar's the oem wiring.
Old 09-11-2022, 01:39 PM #6
88maroon 88maroon is offline
88maroon is on a distinguished road
I had to do a bunch of research when I was installing my diodedynamics elite series fog lights with amber backlighting. I decided to buy SS3 pros to put behind my grille with a 3 way switch in the cabin. Tapped into the SS3 with the elite series foglights so I can control both with a flip of a switch.
Diode Dynamics SS3 backlight question-306296577_1094348121220619_2943197308389111306_n-jpg  Diode Dynamics SS3 backlight question-305653498_595917765543972_7386504422762116062_n-jpg  Diode Dynamics SS3 backlight question-305691034_769156024392719_1714585175893669868_n-jpg
2022 ORP MGM. Dobinsons IMS lift 3in front & 2in rear. C59-314 front coils, IMS59-50700, C59-325 rear coils, IMS59-50701, Dobinsons uca. Thinkware U1000 front/ rear dash cam, powercell 8 powerbank.
88maroon is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 01:48 PM #7
mrblah's Avatar
mrblah's Avatar
That’s not exactly what the op was asking
Old 09-11-2022, 02:32 PM #8
I just gave him another way I turn on the backlight function. If he ever wants to put ditch lights with the three way switch he can tap into the ditch lights. Or he can get a brite box and do it that way.
Old 09-12-2022, 01:52 AM #9
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
A little off topic, my apologies. I am going to be getting a pair of DD SS3 yellow fogs to replace my own fogs(2018 4Runner). Living in So Cal and running with my fogs on all the time, would I be better to go with the Sports or Pros? TIA
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 09-12-2022, 07:46 AM #10
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
You shouldn’t run your fogs all the time. If you want the look of the lower lights on, get the backlit ones and run the backlight all the time. If you’re going to run them full blast anyway, be less of an ******* and get the Sports. The Pros have a taller pattern IIRC and are therefore more blinding
NB17Limited is offline   Reply With QuoteReply With Quote
Old 09-13-2022, 04:01 PM #11
mrblah's Avatar
mrblah's Avatar
id get the sports, if you want to use it all the time legally on the road. I have other off-road lights, i can count on for offroading.
If you want to run with fogs on all the time, go for it bro, just make sure you are considerate of others.
the backlighting on the ss3 is not as bright as pictures show. They are not bright enough to act like DRL lights, so running fogs on during the day time as a DRL is a good idea.
Old 09-14-2022, 12:36 AM #12
Thanks. I went ahead and ordered the Sports without the backlit option. I will have them aimed low so I don't irritate anyone. I like the fill in light for night driving, inclement weather and dust when following off road. And the safety and cool factor during the day.
I am going to install these at the same time as my Warn Lo Pro and put my PIAA LP560's on top of the bumper. I like the traditional round look.
I need to upgrade my headlights, low and high beams. I don't want to spend $1000 on headlights. Any feedback would be appreciated. 2018 4Runner.
Anything else I should think about doing with the front fascia/bumper off?
Old 09-14-2022, 02:31 AM #13
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Just my opinion as a professional driver
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 09-14-2022, 08:16 AM #14
H9 with trimmed tabs will be the best performance in your low beam. High beam already does well but if you want to change it, get a high performance 9005 halogen. I think there is an upgrade path for that bulb but I can’t remember what it is. You can also troll FB Marketplace, forums, and CL for some ‘21+ OEM takeoffs. Usually under $700 and are the best performing headlights for the 4Runner. It will require a harness from Headlight | FBC Harness Solutions.
If you are dead set on putting LEDs in your headlights to make them look more modern and don’t want to wait for some OEM headlights, according to this very thorough thread of testing (3rd Gen HID vs LED vs Halogen H11 projector headlights | Tacoma World), the Morimoto 2 stroke and Hikari Ultra are decent. They will underperform compared to the H9.
If you don’t want to take the bumper off often, maybe add some auxiliary high beam pods?
Old 09-14-2022, 03:28 PM #15
Thank you for that information. I was trying to remember what the bulb (H9) mod was called with the trimmed tabs. 9005’s in combination would be an inexpensive mod. A 21+ upgrade would be nice, but is a little out of budget, although I will keep looking prior to installing everything in 12 days.
Which type of auxiliary high beam pods are you referring too? Are you thinking about an SAE/DOT option that can be wired into the high beams to work in synchronization?
backlight , fog , function , lights , ss3
Diode Dynamics SS3 LED Fog Light SidKo 5th gen T4Rs 32 07-30-2023 01:58 PM
Diode Dynamics SS3 SAE PRO Fog lights burnurass For Sale: T4R Items 7 12-11-2020 01:23 AM
Experience with Diode Dynamics sugjavier 3rd gen T4Rs 14 12-03-2020 12:12 PM
Diode Dynamics HID? TheJokingExplorer 5th gen T4Rs 1 02-08-2018 10:28 PM
