Real Name: Kirk
Real Name: Kirk
WD hitch
Originally Posted by Sicnarf
In my research I have found conflicting and very thin info on if a weight distribution hitch can be used with a 4Runner. I have a 2021 TRD Pro. Can I use a WDH on my 4Runner? TIA!
Yes you can. But it takes a little research.
I have a 2019 PRO using a Draw Tite Class IV frame mounted hitch that was intended for the Australian Market Prado 150. Found it on AMAZON.
NOTE: it DOES require some minor enlargement of the forward set of mounting holes, a Dremmel tool with a carbide bit is your friend here.
That and a WD hitch and you are good to go to a 550lb tongue weight and 5500 GTW.
The stock 4Runner may not like it, but the frame mounted hitch adds a TON of piece of mind. Currently running this setup with no issues at all.
Good Luck,
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
