East Coast Gear Supply makes the replacement bushing for the needle bearing in the front "clamshell".
TOYOTA 8" CLAMSHELL CV AXLE BUSHING
I just had it installed at about 118K. Not so much because the needle bearing was worn but more so because the inner CV joint seal blew for the second time on me. First time was replaced under warranty at around 45K. So the second seal lasted longer but I figured since they were going to be in that part of the Diff anyway, might as well do the needle bearing replacement. I was getting a slight rumble from the front just around 20 mph. It was a faint rumble more closely resembling driving on a rumble-strip but not that pronounced.
I had it done at a local, trusted mechanic so I can't tell you how hard it was. They billed me for 2 hours of labor to do it. I don't have the confidence to mess with spilling gear oil and pulling steering links, steering knuckle, pulling the CV out etc. to do it on my own. Others have done it themselves in their driveway so you be the judge based on your skill, patience and confidence level for these types of jobs. I did buy the removal tool that ECGS sells and left it with the mechanic as a favor since the tool would see more use at their shop than in my spare parts bin at home.
No more rumble from the front end.
