Real Name: Jeremy
Real Name: Jeremy
You think the 4R is bad you should try owning an older Bronco..those were notorious for water penetrating via clogged drainage holes and bad weather stripping. I would assume Toyota has done a much better job with solving for this problem..that area is never going to be water tight, so if some water finds it's way into the tailgate it will run out of the holes, but it should never makes it's way into the cargo area.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
