I doubt any mechanical trouble with the transmission or torque converter would be one and done. If you're concerned, it might be time to drain the fluid out of the transmission, wouldn't hurt to change it anyway, especially if it hasn't been done before. There are tutorials online on how to do this, it's not hard at all. Drain the fluid through a coffee filter, check for any excess metal shavings, etc. Be sure to refill with genuine Toyota ATF WS. Up to you whether you want to drop the pan and change the filter (pickup screen) at that mileage. Although there are magnets in the pan that you can check for debris if you believe there is a problem.
Honestly what you describe sounds more like a brake that was stuck for whatever reason. I'd probably be chasing that before I go after anything that has to do with the transmission.
