09-19-2022, 08:58 AM
Are 35s really the answer for off-road driving?
I’ve always been a believer that 33 inch tires are the perfect size for our platform. This is when you think of mechanical reliability, affects on on-road performance and the level of effort to get things working properly. However, curiosity killed the cat and with a couple of really technical trails on my list for the next month I decided to upgrade. I didn’t want to go to a full size 35” tire so I decided to go BFG K02 in the 315/70/17. These tires are notorious for being undersized and at 62.4 lbs they were pretty light.
Mounted they stood just about 34” tall. Here is one mounted on a wheel next to an unmounted 285/70/17 Ridge Grappler with about 99% tread left.
As you can see once mounted it was really apparent I needed to do a ton of clearancing for these to work off-road.
So off I went to grind down more body mount and to flatten the pinch welds.
I had a camping trip planned this weekend so I knew I would be able to test them out. Before I went out I did a 100 mile loop to get some initial pavement impressions running a tire of this size with stock gearing. Here’s what I thought:
1. Power - There was definitely a hit on power but it wasn’t as bad as I expected it to be.
2. Engine Speed - RPMs at highway speed are lower than my previous setup. So at 65 mph my engine was spinning at just about 1600 rpms.
3. Transmission - Transmission temps and shifting were fine even when climbing a mountain pass
4. Gas Mileage - Fuel economy was still decent with average highway speeds around 65 mph. I returned 17 mpg hand calculated at the pump using the TFLTruck method over that 100 mile loop. I was really surprised by this.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
09-19-2022, 08:59 AM
Now it was time for some off-road driving impressions. We had a weekend up in the Western Sierras for some mountain biking and moderate wheeling. So I thought it would be a perfect opportunity to test clearancing. I removed my fender flares ahead of time because I knew they would be a problem.
So off into the mountains we went to find some great campsites and rocks and ruts to play on.
As expected the tires showed me where I needed to do more clearancing at full compression. Fenders need to be cut, BMC dialed back and firewall beat back.
So the real question was how did they do off-road? Here is what I think:
1. Steering - I definitely felt an increase in bump steer when going over rocks. Not surprising since these larger tires have a lot more rolling mass.
2. Clearance - It was nice to be able to roll over larger rocks without tagging my skids and rear bumper. I’ve done the rockier part of this trail many times before and there was definitely a difference there.
3. Crawl Ratio - When in 4 low the negative impact of messing up my crawl ratio was felt. The truck was rolling faster especially in 2nd which meant much more brake modulation descending steeps and crawling rocks. Obviously this will be corrected with gears later down the road.
4. Traction - Traction felt it was a bit reduced on dry loose rock vs. my Cooper ST Maxx I ran previously. Not surprising since these have a much less aggressive tread.
So for me the jury is still out on this size tire from my perspective. It required a lot of work to fit and will need even more in the future to do this really right. I also question the durability of the stock steering components now that they are turning such huge tires. I foresee also having to upgrade the rack in my relatively near future. Although I heard upgrading to an LC200/Tundra rack doesn't really solve things either.
At the end of the day these types of mods have diminishing returns and are also a balance of capability and durability. I think I may have overstepped a bit and upset that balance but time will tell. I have a 7/10 technical trail run coming up in a couple of weeks. So I'll really be able to put the new setup through its paces. I just hope I dont break anything trail side
09-19-2022, 09:41 AM
35's are for the 'gram bro
09-19-2022, 10:03 AM
for the reasons you pointed out, the 33s are a good "governor" that keeps me off anything too radical and breaking stuff all the time.
the question is...do you want a rock crawler that can go anywhere with less reliability....or a swiss army knife that can do most things well, but not all great, and remain reliable.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
09-19-2022, 10:57 AM
Thanks for posting this. Every time my tires start to get thin on tread I think about going to a 35.
You're on stock gears IIRC?
What is your caster set at now?
Wheel width and off set?
I know it's all in your build thread but I thought others might gain insight from this
09-19-2022, 11:23 AM
285/70/17 all day but 285/75/17 might be a happy medium between "33s" and "35s". It fits with about the same effort as 33s, same contact patch but slightly taller, and less wear of you steering and drivetrain components than 35s. I personally think what type of tire has more impact on our 4runners than actual tire size. Of course, a Rubicon on 35s or 37s will out perform but its setup different than us. On Top of the World, I noticed my Yokos gripped better on the uphill portion and slid alot less coming down than my buddies and I am a lot heavier than them. Maybe it was my brake and throttle modulation, but I like to think it was my tires...and probably my gearing lol
Reason: Said White Rim, meant Top of the World LOL
09-19-2022, 11:46 AM
Narrow 33's are the answer??
I agree,, 33's are a happy place to stop. They have a near negligible effect on the daily driven aspect of my truck, and are just big enough to tackle everything offroad I want to (note. Sliders, skid plates, and good armor is just as important. )
I have had really positive experiences with Nitto Ridge Grapplers in 255/80s on mine. they stand about 33.3" tall, and are narrow enough on the TRD-Pro wheels to have clearance at full articulation with no need to chop body mounts. Aired down, they are a great tire option in the PNW in every season but winter....
Eibach 1.6in LIft springs and 0.25 in spacer in the front
Eibach +200lbs load leveler system in the back
RSG Angled Sliders
09-19-2022, 11:49 AM
I think for the average user, 33s are perfect. They look good and they do 99.99% of what people want them to do.
I just made the jump to 35s and it's been a lot of work - even with a much narrower tire. I had to have my BMC redone and cut further back, I've cut and hammered the pinch weld, I've hammered the inner fender, I've cut the fender trim, but not the actual fender yet. Every couple of days a trim a bit more, look for more rub, trim a bit more, look for more rub, etc. Honestly if I just removed my wheel spacers and used a wheel closer to a -10 offset, I'd be golden.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
09-19-2022, 11:51 AM
OP a question on the tires
I see you went with 315s? I was wondering why? Arent wider tires mostly for floatation in mud? If so why the K02s? I have K02 and like you probably know its a great gravel and light dirt tire but a shit mud tire. So why the need for the extra punishing weight and width of the larger tire?
Not knocking your choice just wondering where the tradeoffs make the larger diameter worth it? Is it really that much better?
09-19-2022, 12:01 PM
100% its definitely a balancing act and hard to nail down. My truck is a dedicated off-road vehicle that travels far distances on pavement to get to fun. I also love very technical trails and testing my equipment's durability. In some weird way I like when things break because I know that I'm really using them.
09-19-2022, 12:07 PM
Ah good call, I mentioned being on stock gearing but I guess it was a bit buried. The gearing obviously affects power and the crawl ratio which would be both solved with gearing to 4.56 or even 4.88. However, I know changing the gearing will most likely result in a negative impact on fuel economy. Which is a factor to consider of course.
Caster is set to 4.1 driver and 4.0 passenger, that is the max you can get with Icon UCAs. My rims are 17x9 with a -25 offset which doesnt make things easier. However, even with a 0 offset wheel I can't see a world where you're not hitting your fender flares at full compression.
09-19-2022, 12:08 PM
Yup its definitely a work in progress but I guess that is the fun part right?
09-19-2022, 12:11 PM
I went with 315s because I do a lot of snow wheeling in conditions where the snow is very deep and I need flotation. Also mud is pretty rare here outside of the PNW and most of my wheeling is over dry rock which K02s are great on.
09-19-2022, 12:18 PM
I blew the end cap off the stock steering rack on the trail with 160k miles on the truck and 35's. Fluid went everywhere and I limped it off the trail.
However I haven't had an issue wheeling with that same rack and 37s. Haven't even broken a tie rod or a CV. This is on the Rubion, Fordyce, and Blanca Peak. Goes to show no matter your tire size you always have to prepare for the worst on the trail.
I grenaded the rear diff right after installing 35s on the trail but a rebuild with a solid pinion spacer would have prevented it, and the 5th gen rear diff is stronger than my 4th gen's. I upgraded to a dana 60 which is good for 40s.
A LC200 rack should be good up to 40s and is only a couple hundred more expensive than a stock steering rack.
So yeah I've had some breakage but nothing that can't be beefed up in advance, the only real expensive item is the rear diff solid pinion spacer but can be taken care of alongside a regear and lockers. And maybe the 5th gen rear diff is strong enough to handle 35s but I've seen at least 5 guys with factory untouched 8" rear diffs grenade them on 35s with 4th gens and FJs. But like I said once you replace that crush washer with a solid spacer it should be fine with 35's especially your 8.4 diff.
09-19-2022, 12:27 PM
I'll be interested to see how you sort it all out. You may need some longer bump stops.
What altitude do you wheel at?
