Old 09-19-2022, 07:11 PM #1
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
Help - Squeak after axle / needle bearing replacement
Axle and needle bearing were replaced with oem by Toyota shop 2-3 mo ago.
Zero noise solved my issue of the needling bearing noise.
Noticed between 25-30mph a squeak that I thought was maybe brakes?
Noise still occurs applying brakes.
Thought was suspension components.
Lubed all components - uca, ball joints, lcas, pivot points, anything that moves with suspension
Still occurring
Noticed tonight noise does go away if I accelerate but if holding speed or coasting it comes back.
Thought maybe drive axle but the squeak doesn’t occur as fast as the wheel is spinning (frequency)
Going to try and remove splash shields and lube case mounts next…
Aftermarket icon suspension and ucas (ball joints replaced 4mo ago) - lubed shock shaft and have covers installed for salt erosion etc.
Greased hood stops - didn’t work
Don’t think it’s a belt as reving engine or idle cannot replicate.
Ruling out suspension as rocking car or bouncing cannot replicate…
Video (faint but louder in person)
- YouTube
Any help or advice is appreciated!!!
Jealousy is ugly... Don't be ugly.
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 08:07 PM #2
Also aftermarket ark splash guards do it’s not the infamous clip sounds - arms are on there super tight.
Sounds like exactly like that sound as I had that issue to when first got the vehicle
axle , noise , squeak , suspension , thought
Axle Bearing Replacement Turned Into Much Bigger Job! WrenchTech 3rd gen T4Rs 2 09-28-2020 05:18 PM
Front Differential needle roller bearing replacement LTDSC 4th Gen T4Rs 34 02-16-2020 10:00 PM
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Needle Bearing and CV Axle kremlon 3rd gen T4Rs 11 04-27-2017 09:26 PM
Rear Axle Bearing (Replacement) CVELD77 3rd gen T4Rs 2 08-07-2015 10:50 PM
