Old 09-22-2022, 01:36 AM #1
rodralig rodralig is offline
rodralig is on a distinguished road
'18 ORP - Rear Brake Fail at 20K!?! Rear Brake Pad wear at 15K!?!
Something strange happened to our ’18 ORP. My wife called me up that there was a leak on the rear right tire assembly. There was some grinding sound and braking was bad. I was at work, so, I told her to have it towed to the dealer.
The assessment was that the brake system was shot up, ie., the brakes got run into the caliper with the pistons and rotor damaged. $$$ estimates about $1.6K. *ugh*
This is my wife’s daily driver - any ideas on root cause? Dealer says that she should have felt something off with the brakes before it came to metal to metal, but I was told by my wife that she only heard the noise, etc. this morning. Odometer is at 64K.
I will be taking a half day off tomorrow to visit the dealer and get some details; but insights from the collective knowledge of the group would be most appreciated.
In hindsight, as I look through our maintenance records, the rear brake pad seems to wear every 15K-miles... This is FAST!?!
Thoughts on troubleshooting?
TIA!
rodralig is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 07:36 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If you want to save about $1K, do the repair yourself. Sounds like a seized caliper, not uncommon. Replace it, rotor and new pads on both sides. Inspect front and go from there.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 09-22-2022, 08:43 AM #3
John in NC John in NC is offline
Real Name: John
John in NC will become famous soon enough John in NC will become famous soon enough
Real Name: John
My back left caliper was dragging, cost me an early brake job and a ton of brake dust everywhere, and plenty of MPG I'd assume.
John in NC is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 09:03 AM #4
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
The savings would be more like $1.3K by doing it yourself. Takes less than an hour per side.
Advice: make a point of driving your wife’s car more often so that you can catch things like this before they become a big fail.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 09:31 AM #5
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
Yup, common. Fix and move on.
I do all the brakes for our vehicles. Disc brakes are the bomb.com compared to drums. Drums are the devil's work.
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 10:39 AM #6
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
Did you put a "leveling" kit in without resetting zero point calibration? If so, that's likely part of the problem.
Jetboy is online now   Reply With QuoteReply With Quote
Old 09-23-2022, 12:19 AM #7
I saw the parts - dang! Both rear brake pads are like way RED... The rear right pad was toast - pistons damaged; while almost nothing remaining on the rear left. This is about 20K miles... I will try to observe it more and see the wear in 5K miles. Question is - something wrong with the 4Runner (calipers dragging, parking brake, etc.)? Or the wife's driving habits?
I used to do that until COVID, ie., at least that 10-miles run every month just so the 4x4 oil gets circulated (when not engaged, etc.)... When I replaced my own driver with a manual, which my wife couldn't drive, the 4Runner became exclusively hers... I am making a point to spent time driving the 4Runner on a weekly basis going forward.
Stock.
_
Old 09-23-2022, 12:44 AM #8
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Are rear brake pads only lasting 20k miles? Something is wrong or your wife has a unique driving style. My wife's 2017 has original pads at 27k miles, all city driving. My 2018 has original pads at 25k miles. Mostly city miles.
My 2006 Dodge 2500 has original brake pads at 130k miles. Most of those miles are towing heavy. Pads now at 50%.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 05:32 AM #9
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
Don't think it would be her driving style as the front brakes should wear out before the rear.
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 05:57 AM #10
Hungryhawk Hungryhawk is offline
Hungryhawk is on a distinguished road
Rear brake problem
This is interesting failure. Corrosion on or in rear caliper seems a possible cause? Has brake fluid been changed? You can learn a lot from brake fluid pumped out caliper bleed fitting: is it black , brown or clear? Front caliper fluid exam might shed light on the rear caliper problem.
Do you drive on icy roads that get salted?
I bought Honda rear brake pads for my Pilot from internet source several years ago and they were clever counterfeit. I discovered 1mm lining left after 17,000 miles and fortunately no damage to the rotors. Now I only purchase brake parts from dealerships.
If corrosion is not obvious culprit, then there are electronic issues to consider with our 4runners.
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 08:47 PM #11
gomiami's Avatar
gomiami gomiami is offline
Real Name: Jay
gomiami has a spectacular aura about gomiami has a spectacular aura about
gomiami's Avatar
Real Name: Jay
If it had been a seized caliper, your garage would have been break dust city. My Civic SI developed a seized rear caliper and I smelled the dust, noticed the drag and saw the wheel was coated within a day.
For your wife to say it just happened suddenly (and with that much damage) is fascinating.
2000 Honda Civic SI (EM1) Electron Blue Pearl - original owner, 238k and completely stock.
2023 Lexus GX460 Premium in Nightfall Mica. Picking up on January 2nd.
gomiami is offline   Reply With QuoteReply With Quote
brake , brakes , dealer , orp , rear
Need help: rear brake piston stuck (pressed brake with pads out) slide531 5th gen T4Rs 5 11-10-2021 09:19 PM
Weird Rear Brake Wear ted4r 4th Gen T4Rs 8 11-13-2017 05:50 PM
Rear brake lines exploded while bleeding brake fluid benztech82 4th Gen T4Rs 3 08-11-2017 08:16 PM
Rear Brake Pad Wear - Normal? JayceeP 5th gen T4Rs 1 08-31-2014 09:22 AM
First brake job - Can someone recommend rear brake pads for 2008 SR5 V6? ddicosmo 4th Gen T4Rs 25 03-03-2014 03:23 AM
