Old 09-23-2022, 12:42 PM #1
dcjeeper dcjeeper is offline
dcjeeper is on a distinguished road
Should I switch to Mobil 1 high mileage?
My 2016 SR5 has 75k miles now. It runs well without any leak. I’m changing oil again and wonder if I should switch from Mobil 1 Fuel economy ow-20 to M1 high mileage ow-20? I see the HM label says for engines with 75k and above. Not sure if there is any advantage now. What do you use when the mileage is up to 75k?
dcjeeper is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 01:10 PM #2
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I use toyota or lexus 0w20 and am at 240,000 miles, can get for same price as M1 if you talk to the parts guys.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 03:44 PM #3
Matt831 Matt831 is offline
Matt831 will become famous soon enough
What does the high mileage oil actually do? Some different additive package?
I would run Toyota 0w/20. It is great oil, look up some breakdowns of it.
Matt831 is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 03:47 PM #4
BC2ndgen BC2ndgen is offline
BC2ndgen is on a distinguished road
Pretty sure HM oil has extra additives in it. Ive always had older Japanese cars and have ALWAYS ran Rotella Diesel oil in them and they absolutely loved it. Its cheap and works great. Has extra detergents in it.
BC2ndgen is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 03:49 PM #5
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
We’re at 310K miles on a 2014. Lately been using Quaker State 0w20 synthetic as it’s
Cheapest, but also one of the highest rated. I’ve also run Rotella gas truck 0w20 synthetic, for the same reasons.
I think the high mileage oils have additives to prevent or stop leaks.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 05:59 PM #6
mmike87 mmike87 is offline
mmike87 is on a distinguished road
75k isn't high mileage, especially not in a 4Runner.
Sent from my SM-N986U using Tapatalk
mmike87 is offline   Reply With QuoteReply With Quote
Old 09-23-2022, 09:16 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
High mileage oil supposedly helps the seals and gaskets that are in contact with oil remain pliable (not get hard and brittle). I use Valvoline 5W30, but I have a 4th gen V8. Been using it for 6-8 years. No leaks!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 09-23-2022, 09:53 PM #8
Originally Posted by djeepin View Post
why would I use inferior oils compared to superior Toyota 0W20 oil? What other oil has molybdenum content 760 like Toyota?
Thanks for the daily laugh.
Old 09-24-2022, 01:28 PM #9
PETROLEUM QUALITY INSTITUTE OF AMERICA - all oils tests are there.
Read up, post #14:
Just a moment...
“High moly was in order to increase the fuel efficiency of 0W-20 even more so that Japanese cars would have their unbeatable fuel economy, not only helped by the high VI and low HTHS viscosity of 0W-20 but also the low friction of synthetic base oil and even lower friction thanks to high moly. However, after Infineum (an ExxonMobil - Shell joint venture) additive company's patented trinuclear moly became famous, Japanese folks also learned that 50 - 100 ppm of trinuclear organic moly does a better job in friction reduction and antiwear, antioxidation protection than 1000 ppm of traditional organic moly. Therefore, apparently, Toyota 0W-20 SN made by ExxonMobil uses trinuclear organic moly now. The tests show that 50 - 100 ppm trinuclear moly when used along with standard amounts of ZDDP greatly reduces wear and friction. Therefore, it also reduces the requirement for high ZDDP. Also note that trinuclear moly is used in Mobil Delvac 1300 Super HDEO as well: "Trimer additive technology is a patented additive technology that imparts outstanding wear performance, effective oxidation resistance and improved frictional properties while contributing little to the overall ash content enabling Mobil Delvac 1300 Super to deliver performance beyond the boundaries of industry requirements of API CJ-4." Trinuclear moly is probably the second most effective additive in engine oil, only second to ZDDP. However, the two need to be used together anyway, which makes it one of the two most important additives in the oil.“
So in summary, the competing oils were using Trinuclear Organic Molybdenum “Trimer”, while Toyota was using old school Molybdenum. You can use far less Trimer to get the same effect. Current Toyota oil is made by ExxonMobil and uses Trimer, so there is far less of your beloved Moly in it.
No engine oil manufacturer is going to make deficient oil. There is no advantage to using the costly Toyota oil. Even the stealerships do not use it. Finally, scoreboard matters and we have 310K miles on a 2014 SR5, all on non-OEM fluids.
Old 09-24-2022, 02:59 PM #10
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
This
Old 09-24-2022, 04:35 PM #11
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
I've been using Mobil1 0W40 on a P/u for almost 300K miles and other cars
Mercedes, Porsches and the new C8 Corvettes come with this stuff.
Can get a 5qt jug at WallyWorld for 25 bucks.
Better oils like Motul, Liqui Moly, Fuchs, Total Quartz (Elf), Schaeffer Etc just have crazy prices. They all use the modern Moly
Unless you are buying the actual Toyota oil in quarts, I wouldn't trust the dealer for the oil change, a lot of them use other bulk oils.
Here is an ad, but also somewhat of a primer if you drill deep.
https://s2dynamics.com/wp-content/up...-liquimoly.pdf
seatia is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 06:02 PM #12
I checked the PQIA ratings for 0w20 synthetic and even Walmart’s Super Tech got the highest green dot rating.
Old 09-24-2022, 11:38 PM #13
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
No leaks = no need for high mileage.
After 75k I have always used the same thing as before 75k - and never had an oil related issue.
A HM oil contains more seal maintaining ingredients, and will cause some leaks to reseal if the gasket is dried out. You shouldn't have that issue using M1 at a reasonable interval.
OTOH, it will not hurt to use the HM version, and you can switch back and forth if you like.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 02:51 PM #14
MittenMan's Avatar
MittenMan MittenMan is offline
Real Name: Kyler
MittenMan is on a distinguished road
MittenMan's Avatar
Real Name: Kyler
I’ve been using AMSOIL signature series in my ‘07 since I picked it up at 96k miles. Now has 123k and I’ve definitely noticed an improvement in engine health. Previously ran Mobil 1 and never thought it really stood out from the rest. Pennzoil ultra platinum is a great oil as well.
MittenMan is offline   Reply With QuoteReply With Quote
Old 09-25-2022, 07:36 PM #15
Years ago I used Amsoil but couldn't deal with the ridiculous MLM distribution scheme. Felt like I was dealing with my ex-gf's Arbonne.
75k , mileage , mobil , ow-20 , switch
What is High Mileage? yotaah 3rd gen T4Rs 75 08-09-2018 11:10 AM
To buy low mileage or high mileage, that is the question DDeezenuts 3rd gen T4Rs 21 01-08-2016 03:22 PM
Mobil 1 vs Mobil 1 high mileage... runnahmike General Discussions 9 11-19-2010 03:32 PM
High Mileage '96 marcosdavid 3rd gen T4Rs 8 10-18-2007 05:00 PM
94 4Runner & Mobil High Mileage Oil: Comments Please NewYorkRifleMan Maintenance/Detailing 1 07-24-2007 07:23 PM
