Old 09-24-2022, 09:12 AM #1
dcjeeper dcjeeper is offline
dcjeeper is on a distinguished road
How long does the OEM battery last?
My '16 SR5 has 75k miles and is still on the OEM Panasonic battery. It works fine but I plan to replace it in a few months before winter comes and it fails. The car is 6.5 years old since I purchased it. When and what was the mileage when you replaced yours? Should I replace it soon?
dcjeeper is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 09:46 AM #2
RobS10's Avatar
RobS10 RobS10 is offline
RobS10 has a spectacular aura about RobS10 has a spectacular aura about
RobS10's Avatar
I think a battery can be load tested to see how it's lifespan is holding up. I know winter will be the hardest on it and you don't want to get stuck, but I would test it before replacing it with no symptoms of imminent failure. They always seem to give a couple death rattle slow crank episodes before totally crapping out. I would invest in a set of good jumper cables (not crappy light gauge cheapos). They are always good to have on hand, if anything, to help someone else that needs a jump.
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
RobS10 is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 10:15 AM #3
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
This is part of what i was going to post. If you feel like you might have battery issues, I'd get it tested, and also, i'd put a multimeter on your alternator and make sure it's putting out the factory charging numbers (usually around 13-14 volts)
All that aside, i've had batteries last as long as 5-6 years on some vehicles and some cheaper units last less than 3 years. Vehicles on a trickle charger or battery tender can last indefinitely if they're cycled properly.
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 10:17 AM #4
NoSoupForYou's Avatar
NoSoupForYou NoSoupForYou is offline
NoSoupForYou is on a distinguished road
Jumper cables are great to have for sure. Better yet OP, may be worth investing in something better like one of these Amazon.com: NOCO Boost HD GB70 2000 Amp 12-Volt UltraSafe Lithium Jump Starter Box, Car Battery Booster Pack, Portable Power Bank Charger, and Jumper Cables for up to 8-Liter Gasoline and 6-Liter Diesel Engines : Automotive . I keep one fully charged in my 4R. Had to use it for the first time the other night with my 240z, and holy crap I thought the damn engine was going to fly out of the car with how fast it spun and how long off this thing.
NoSoupForYou is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 10:23 AM #5
RobS10's Avatar
RobS10's Avatar
Wow, Li Ion battery tech is crazy now!
Old 09-24-2022, 10:54 AM #6
Yeah it's crazy. I also have this big ass jumper box thing that must weigh 30 lbs I used to use. That little noco thing is like..2lbs? maybe? It's a great investment! People always get a kick out of it.
Old 09-24-2022, 11:30 AM #7
RobS10's Avatar
RobS10's Avatar
Your friends are probably like "WTF is that thing??"
We have one of those jump boxes as well, but too big and heavy to keep in the vehicle. The little Li Ion do hickey is perfect size. Guess the main thing is remembering to keep it charged.
Old 09-24-2022, 11:32 AM #8
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Replaced the original Panasonic battery in my 17 last year.
This is in AZ which is brutal on batteries (and most everything else)
Sent from my SM-S908U using Tapatalk
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 11:40 AM #9
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I replaced the OEM Panasonic in my 2004 (bought in 9/2003) with a Toyota (Interstate) in 11/2015. I still have the Panasonic and it charges up and holds at 12.5 volts. The parts guy said "no, we can't get the Panasonics....wish we could. They are a great battery". I use the Panasonic to jump neighbors' batteries in winter. I keep it on a monitoring battery charger. (BTW, even though the battery is sealed, you can unscrew the little caps to add distilled water if needed.)
The Panasonic was working just fine at the time I replaced it. It was coming into winter and I was pulling a travel trailer down to Florida then over to Texas. We were to be 3 months on the road and I didn't want to have any starting worries. I'm still using the battery I bought in 2015.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 12:36 PM #10
I bought a smaller one about palm size and it works well, but can only be used twice when fully charged. Don’t like the usb charger though. Wonder why don’t they include a standard charging cable?
https://www.autozone.com/test-scan-a...ter/567690_0_0
Old 09-24-2022, 02:30 PM #11
bglfgd bglfgd is offline
bglfgd is on a distinguished road
2016 with 80K miles here, original battery still going strong without any signs of impending failure, don't plan on replacing until it starts showing its age. Of course, now that I said all that it'll probably crap out on me next week ...
Sent from my SM-G998U using Tapatalk
bglfgd is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 02:43 PM #12
jmsdad jmsdad is offline
jmsdad is on a distinguished road
Good time to replace it with a new one if you're doing any remote trips. Would suck to be stranded
jmsdad is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 03:55 PM #13
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
‘18 SR5 w/50,000 miles. Still running the OEM Panasonic. No corrosion, never have serviced it. Truck is regularly used over dirt roads and trails, in snowy winter weather, warm summers.
I bought an ‘02 Tacoma TRD 4x4 pickup new, which had a Panasonic battery. Replaced it in 2009 when the truck had over 100,000 miles on it. It was during winter with subzero weather. If run daily it would start. If attempted without running it the day before, it would just click. I jumped it with my jumper box a few times then replaced it.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 04:07 PM #14
jmarthsr jmarthsr is offline
jmarthsr is on a distinguished road
Replaced my 2014 trail last spring jut because summer was coming here in Texas.
jmarthsr is offline   Reply With QuoteReply With Quote
Old 09-24-2022, 04:33 PM #15
Jon S Jon S is offline
Jon S is on a distinguished road
On my 3rd battery on my '16 sr5. One replaced under warranty, next one was prorated. I'm in CO
Jon S is offline   Reply With QuoteReply With Quote
battery , fails , oem , replace , winter
How long your OEM battery has lasted? BADCUDA1 4th Gen T4Rs 16 05-03-2020 09:52 PM
How long will the battery last with the key on ACC but no accessories on? adaml 5th gen T4Rs 18 09-28-2017 01:54 PM
HELP! Battery Cable not long enough for new battery TerraCrawler General Discussions 11 08-02-2017 10:24 PM
How long do you run a battery before replacing it? Ralph Blake 4th Gen T4Rs 20 09-09-2016 06:37 PM
how long does the battery last? tonybaloney 4th Gen T4Rs 7 11-11-2007 02:08 AM
