09-27-2022, 08:49 AM
Damaged Rear Lower Link Mounts
Well I think I finally figured out what was causing the noise in my rear when I fully flexed out my rear suspension. After repeated rock strikes it looks like my rear lower link mounts are pretty beat up on both sides.
It is the one area I didn’t armor up which in retrospect was a mistake. It also appears that these mounts tend to get like this just from repeated full flexing of the rear suspension off road.
What have been your experiences fixing this? I think the short term play is to bend the mounts back the best I can and throw some skids on there. Long term I may cut the original mounts off and weld newer beefier ones in.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
09-27-2022, 09:18 AM
I think
@ eimkeith
makes a solution for this that is a weld on bracket reinforcement.
Edit: here Lower Link Mount Skids/Reinforcement – eimkeith.com
09-27-2022, 09:30 AM
I think you have a good plan. Straighten, then reinforce with RCI or other similar type skids. It might not be a bad idea to tack weld the skid to the frame in a few spots once bolted on just for extra beef
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
09-27-2022, 09:32 AM
Originally Posted by jdm-v35
Whoa, those are BEEFY! I love the smooth transition from frame to skid that those offer.
09-27-2022, 09:59 AM
Yup they definitely look like a great option for sure.
09-27-2022, 11:23 AM
Yeah I ended up doing the same to mine and bending the trailing arms also so ended up replacing those. I used the Metal Tech lower link skids and they've worked well. Although they don't look to cover as well as those emkeith do.
OPOR Toyota FJ Cruiser & 4Runner Lower Link Guards
09-27-2022, 11:59 AM
eimkeith like several people already mentioned
I currently have some bolt on skids(dont remember which company) and I've hit those several times in Moab. But I plan on upgrading to this in the near future. Need to fix my front LCA first...
09-27-2022, 10:58 PM
Yep, one of the first things to get destroyed in the rocks. Pull the arms out and use BFH and large crescent wrench to bend things back straight-ish and add the armor of your choice
09-28-2022, 09:12 AM
That is for sure the plan for now.
However, just from my research and going back under the truck I don't know if this is 100% from rock strikes. It does appear that the mounts also get like this from repeated full articulation of the suspension. To be fair we are exceeding stock specifications with extended shocks and increased axle weight from larger tires. Either way I may have to cut them out and replace them with something a little beefier if my initial fix doesn't work. Will update the thread as needed
09-29-2022, 05:23 AM
Real Name: Mark & Merri Morrall
Like others have mentioned, this is what you need:
You need these for your Toyota 4Runner! - YouTube
09-29-2022, 09:38 AM
Dam it, more chit to put on my list to buy!
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
