Old 09-27-2022, 08:49 AM #1
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Damaged Rear Lower Link Mounts
Well I think I finally figured out what was causing the noise in my rear when I fully flexed out my rear suspension. After repeated rock strikes it looks like my rear lower link mounts are pretty beat up on both sides.
It is the one area I didn’t armor up which in retrospect was a mistake. It also appears that these mounts tend to get like this just from repeated full flexing of the rear suspension off road.
What have been your experiences fixing this? I think the short term play is to bend the mounts back the best I can and throw some skids on there. Long term I may cut the original mounts off and weld newer beefier ones in.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 09:18 AM #2
jdm-v35 jdm-v35 is offline
jdm-v35 has a spectacular aura about jdm-v35 has a spectacular aura about jdm-v35 has a spectacular aura about
I think @eimkeith makes a solution for this that is a weld on bracket reinforcement.
Edit: here Lower Link Mount Skids/Reinforcement – eimkeith.com
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 09:30 AM #3
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
I think you have a good plan. Straighten, then reinforce with RCI or other similar type skids. It might not be a bad idea to tack weld the skid to the frame in a few spots once bolted on just for extra beef
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 09:32 AM #4
Whoa, those are BEEFY! I love the smooth transition from frame to skid that those offer.
Old 09-27-2022, 09:59 AM #5
Xtremluck's Avatar
Xtremluck's Avatar
Yup they definitely look like a great option for sure.
Old 09-27-2022, 11:23 AM #6
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all comtn4x4 is a name known to all
comtn4x4's Avatar
Yeah I ended up doing the same to mine and bending the trailing arms also so ended up replacing those. I used the Metal Tech lower link skids and they've worked well. Although they don't look to cover as well as those emkeith do.
OPOR Toyota FJ Cruiser & 4Runner Lower Link Guards
'13 TE w/ KDSS, 4:56 Gears, Dobinson's IMS C59-352/C59-701V, Sonoran Steel KDSS Trac Bar, Overland Custom Design Control Arms. Fuel Revolver 17x9 +1 mm 5" Backspace, Falken Wildpeak A/t3w 285/75r17, Hefty Fabworks Aluminum Front Bumper and Full Skids, C4 Fab Dual Swingout Rear Bumper, OPOR Sliders, Northstar, Off-Grid Engineering, SPod, Blue Sea, Rigid, Baja Designs, KC HiLites, Stedi, Aplharex, National Luna, Drifta, Goose Gear, RAD Rubber Designs, Viair, Bandi Mount, URD, Gobi, ARB, Warn, Factor 55, Fourtreks, Axia Alloys, Desert Does It, Agency 6
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 11:59 AM #7
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is a jewel in the rough blksubykid is a jewel in the rough blksubykid is a jewel in the rough blksubykid is a jewel in the rough
blksubykid's Avatar
eimkeith like several people already mentioned
I currently have some bolt on skids(dont remember which company) and I've hit those several times in Moab. But I plan on upgrading to this in the near future. Need to fix my front LCA first...
blksubykid is offline   Reply With QuoteReply With Quote
Old 09-27-2022, 10:58 PM #8
Jeremy556's Avatar
Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all
Jeremy556's Avatar
Yep, one of the first things to get destroyed in the rocks. Pull the arms out and use BFH and large crescent wrench to bend things back straight-ish and add the armor of your choice
Old 09-28-2022, 09:12 AM #9
Xtremluck's Avatar
Xtremluck's Avatar
That is for sure the plan for now.
However, just from my research and going back under the truck I don't know if this is 100% from rock strikes. It does appear that the mounts also get like this from repeated full articulation of the suspension. To be fair we are exceeding stock specifications with extended shocks and increased axle weight from larger tires. Either way I may have to cut them out and replace them with something a little beefier if my initial fix doesn't work. Will update the thread as needed
Old 09-29-2022, 05:23 AM #10
WanderlostOverland's Avatar
WanderlostOverland WanderlostOverland is offline
Real Name: Mark & Merri Morrall
WanderlostOverland has a spectacular aura about WanderlostOverland has a spectacular aura about WanderlostOverland has a spectacular aura about
Like others have mentioned, this is what you need:
You need these for your Toyota 4Runner! - YouTube
'17 TRD Offroad
'07 FJ Cruiser.
https://www.youtube.com/c/WanderlostOverland
Our Build Thread; http://www.toyota-4runner.org/5th-ge...d-vlog%3B.html
WanderlostOverland is offline   Reply With QuoteReply With Quote
Old 09-29-2022, 09:38 AM #11
IslandJim's Avatar
IslandJim IslandJim is offline
IslandJim will become famous soon enough
IslandJim's Avatar
Dam it, more chit to put on my list to buy!
2019 ORP KDSS MagGrey RSG Sliders 255/75/17 KM2 MT/ICS Fab above console mount
IslandJim is offline   Reply With QuoteReply With Quote
mounts , rear , repeated , suspension , term
Rear Link Mounts Misshapen StockyStock 3rd gen T4Rs 3 02-04-2022 10:17 AM
Rear upper/lower link bushing replacements robb1887 3rd gen T4Rs 4 12-16-2015 03:54 PM
Frame failure at rear lower control link mount Steve240 3rd gen T4Rs 1 05-20-2015 05:11 PM
97 4runner Lower Rear Link Bolt Size coues7 3rd gen T4Rs 1 08-25-2014 09:24 PM
