Originally Posted by SteveT90
My 4wd indicator light on the dash would only come on intermittently when shifting into 4wd. But the 4runner did go into 4wd mode every time. The repair shop says its a bad transfer case ecu, and the total repair bill will be $1200. I'm already several hundred dollars into this repair for diagnostic costs. Does this sound like a legit repair?
Does it actually go into 4wd? If you have the manual transfer case, it will engage 4wd at the transfer case, but unless the front axle disconnect engages the passenger side CV, you won't have any power to the front axle. You can test it on jack stands - if you engage 4wd and can spin one front wheel and the other is still, the ADD is disconnected.
I would
suspect the switch on the transfer case that tells the ecu that you have shifted into 4wd. Unfortunately, I believe you need to pull the tcase to access it, but I've never had to do the job.
Definitely the type of thing that needs proper diagnostics and not just guessing at it, like I am here. I would speak to the mech and see what his troubleshooting steps were, if he checked the output of the tcase switch at the 4wd ecu connector and it had a good signal, but no output from the ECU to engage the ADD, the diagnosis sounds correct.
