Old 09-29-2022, 11:33 PM #16
Jeremy556's Avatar
Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all Jeremy556 is a name known to all
Jeremy556's Avatar
Originally Posted by SteveT90 View Post
My 4wd indicator light on the dash would only come on intermittently when shifting into 4wd. But the 4runner did go into 4wd mode every time. The repair shop says its a bad transfer case ecu, and the total repair bill will be $1200. I'm already several hundred dollars into this repair for diagnostic costs. Does this sound like a legit repair?
Does it actually go into 4wd? If you have the manual transfer case, it will engage 4wd at the transfer case, but unless the front axle disconnect engages the passenger side CV, you won't have any power to the front axle. You can test it on jack stands - if you engage 4wd and can spin one front wheel and the other is still, the ADD is disconnected.
I would suspect the switch on the transfer case that tells the ecu that you have shifted into 4wd. Unfortunately, I believe you need to pull the tcase to access it, but I've never had to do the job.
Definitely the type of thing that needs proper diagnostics and not just guessing at it, like I am here. I would speak to the mech and see what his troubleshooting steps were, if he checked the output of the tcase switch at the 4wd ecu connector and it had a good signal, but no output from the ECU to engage the ADD, the diagnosis sounds correct.
Old 09-29-2022, 11:39 PM #17
Jeremy556's Avatar
Jeremy556's Avatar
Also, the 4wd ECU is pretty easy to get to under the dash, IIRC, and I have never heard of one failing, so they should be plentiful and cheap from scrap yards.
Old 09-30-2022, 10:55 PM #18
SteveT90 SteveT90 is offline
SteveT90 is on a distinguished road
Yes it definitely goes into 4wd.
The part they say that needs to be replaced is #89533-35250. I google that and see a few show up used for about $100. Curiously no new ones showed up in my search.
I'm not going to do the repair myself. I just wanted opinions as to whether this was a possible correct repair.
SteveT90 is offline   Reply With QuoteReply With Quote
Old 10-01-2022, 10:20 AM #19
fkheath fkheath is offline
fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light fkheath is a glorious beacon of light
Have you shop test the Transfer Indicator switches first. (see above)
The MSRP for the ECU is about $350. Hard to see how a $350 part translates to $1200 repair bill.
fkheath is offline   Reply With QuoteReply With Quote
4wd , indicator , light , repair , total
Help! 260k miles, check engine light, multi terrain light, and slip indicator light dave_b 5th gen T4Rs 21 01-19-2021 09:20 AM
PS light and Slip Indicator Light - 13' 4Runner Jayhawk5G Problems & Warranty Issues 0 09-17-2020 12:50 PM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Indicator light mdjh51 5th gen T4Rs 3 01-01-2019 11:24 PM
Slip indicator light VS VSC light tman100z 3rd gen T4Rs 4 02-11-2015 07:55 AM
