Old 10-08-2022, 07:25 AM #1
RigoRunner RigoRunner is offline
RigoRunner is on a distinguished road
5th gen brake problem
Hi everyone,
Hoping someone can give me some insight into the problem I am having.
I recently decided to clean and grease my brakes. I had some uneven wear on the rotor. I started with the front driver's side, and noticed the pins that maintain the pad position on the front caliper looked a little dry and dirty. I decided to take the calipers off and wipe the dirt off and grease the piston boots and pins and backs of the pads. I went to put it back on and put the brake line back into the caliper. I turned the power on so the master cylinder pump had power. When I pressed the brake pedal, fluid started to leak from where the line goes into the caliper. I figured I needed to tighten it, so once I did that, when pressing the brake fluid started to shoot back up through the fitting. I assumed I had cracked the line, so I ordered new OEM pre bent lines. I have the same issue. It appears the flared end has some wiggle room inside the caliper. I tried to tightend it down, but it still seems to be loose in there.
Any thoughts? Hoping to fix it this weekend.
Thanks in advance!
RigoRunner is offline   Reply With QuoteReply With Quote
Old 10-08-2022, 08:10 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You don't have same problem on passenger side? Maybe some piece of debris got into the fitting bore on caliper and is now mashed into threads not allowing a good seat. I would take a close look in that bore and see if you see anything.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-08-2022, 08:17 AM #3
Hadn't gotten that far. Was the first caliper I started with. I thought I had read somewhere that the fitting needs to be tightened and loosened 10-20 times so it sets properly and dislodges debris. I guess I will have to start with that.
back , brake , caliper , line , started
Having the long brake pedal travel/low brake pedal mystery problem Dragon_EX 3rd gen T4Rs 16 05-19-2021 10:58 AM
Brake problem and Lock problem Fldivemaster16 4th Gen T4Rs 3 05-15-2013 03:45 PM
Brake problem and Lock problem Fldivemaster16 3rd gen T4Rs 1 05-14-2013 02:09 PM
02 brake problem? Idahosr5 3rd gen T4Rs 2 03-22-2011 01:07 AM
Brake Problem Atreyus 3rd gen T4Rs 4 12-08-2009 02:47 PM
