Originally Posted by rdruss
You don't have same problem on passenger side? Maybe some piece of debris got into the fitting bore on caliper and is now mashed into threads not allowing a good seat. I would take a close look in that bore and see if you see anything.
Hadn't gotten that far. Was the first caliper I started with. I thought I had read somewhere that the fitting needs to be tightened and loosened 10-20 times so it sets properly and dislodges debris. I guess I will have to start with that.
