Old 10-12-2022, 12:01 PM #16
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
YES...cuz they stop you when you go fast
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 01:39 AM #17
Lexington's Avatar
Lexington Lexington is online now
Lexington has a spectacular aura about Lexington has a spectacular aura about Lexington has a spectacular aura about
Lexington's Avatar
Originally Posted by Jeckhart83 View Post
is there a difference between TRD pads and pads for the limited?
From my understanding the TRD pads provide better stopping power but the cons are they produce a lot of break dust, have a shorter life span and are harder on the rotors. They also have a specific breaking procedure. If not done properly they can mess up your rotors.
Here is a good write up on Toyota brakes.
Brake Upgrade: StopTech Rotors + TRD Performance Pads | Tacoma World
Lexington is online now   Reply With QuoteReply With Quote
Old 10-19-2022, 05:14 PM #18
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I don't think TRD pads harder on rotors. These pads are grippier but softer compound and will wear out sooner. Replacing them especially up front is 10 min job. Slightly more dust is true but not bad enough where you will notice from over 6ft away.
<<<< is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 05:44 PM #19
honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of
x2 on akebono. fronts i just did with duralast gold rotors. feels great so far. kept the stock rotors to have turned when the duralast ones fail. (autozone product shenanigans)
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS sway bar controller
Old 10-19-2022, 06:54 PM #20
Lexington's Avatar
Lexington's Avatar
Thanks for the info on the rotors. I was wondering how Toyota made the pads grippier with just ceramics. Usually brake pads with better stopping power usually have some type of metallic materials which wear down the rotors faster. I didn’t know if they were using some other type of material. But if the TRD is still all ceramic then the wear should be the same as the OEM pads
brake , oem , pads , suggestions
Need help: rear brake piston stuck (pressed brake with pads out) slide531 5th gen T4Rs 5 11-10-2021 09:19 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Tundra brake caliper leaked brake fluid all over pads, replace or clean pads? Srt4runner 3rd gen T4Rs 8 10-30-2015 12:42 AM
brake pads. my brake pads r squeeling. want to know if Thermo quiet will work spartacus 3rd gen T4Rs 4 04-21-2012 08:00 AM
