Old 10-12-2022, 12:01 PM #16
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
YES...cuz they stop you when you go fast
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 01:39 AM #17
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
Originally Posted by Jeckhart83 View Post
is there a difference between TRD pads and pads for the limited?
From my understanding the TRD pads provide better stopping power but the cons are they produce a lot of break dust, have a shorter life span and are harder on the rotors. They also have a specific breaking procedure. If not done properly they can mess up your rotors.
Here is a good write up on Toyota brakes.
Brake Upgrade: StopTech Rotors + TRD Performance Pads | Tacoma World
Lexington is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 05:14 PM #18
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I don't think TRD pads harder on rotors. These pads are grippier but softer compound and will wear out sooner. Replacing them especially up front is 10 min job. Slightly more dust is true but not bad enough where you will notice from over 6ft away.
<<<< is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 05:44 PM #19
x2 on akebono. fronts i just did with duralast gold rotors. feels great so far. kept the stock rotors to have turned when the duralast ones fail. (autozone product shenanigans)
Old 10-19-2022, 06:54 PM #20
Lexington's Avatar
Lexington's Avatar
Thanks for the info on the rotors. I was wondering how Toyota made the pads grippier with just ceramics. Usually brake pads with better stopping power usually have some type of metallic materials which wear down the rotors faster. I didn’t know if they were using some other type of material. But if the TRD is still all ceramic then the wear should be the same as the OEM pads
Old 07-15-2024, 07:57 PM #21
ejesauer ejesauer is offline
ejesauer is on a distinguished road
For the price, I have had really good luck with Bendix Fleet MetLocks on the front and Bendix Priority One Ceramics on the rear.
ejesauer is offline   Reply With QuoteReply With Quote
Old 09-29-2024, 05:15 PM #22
Willyboz1 Willyboz1 is offline
Willyboz1 is on a distinguished road
Going with akebono after reading this post. Thanks !
Willyboz1 is offline   Reply With QuoteReply With Quote
Old 10-09-2024, 01:52 PM #23
<<<<'s Avatar
<<<<'s Avatar
TRD pads are ceramic metallic, thus better grip. Tradeoff is lot more dust and slightly faster wear on rotors. Please read TRD pads instruction carefully. If I may I'd recommend primary break-in process and not the alternative they offer. Hard stops from 50 to 10 mph times 10, then drive for a while to cool your rotors (prepare to be amazed by pad material transfer to rotors and amount of wear on rotor after just doing that). Don't worry though, it is all normal. If you can live with brake dust on fronts - you will enjoy your awesome initial bite.
P.S. I ditched my stock rotors since last post for EBC GD Series due to superior casting and material resistance to uneven wear. My OEM had to much run-off or "warp" after 2 years of use and develop annoying jolting during slow casual stops with lite braking that felt like uneven surface because during normal to hard effort pulsing went away. It may be concluded that TRD pad wears OEM rotors more due to metallic composition. Just like any performance part - it will have some minuses to it's pluses.
Old 10-11-2024, 01:58 AM #24
Hungryhawk Hungryhawk is offline
Hungryhawk is on a distinguished road
Brake pads
I only use factory pads purchased from a dealer.
I once purchased Honda pads for my Pilot from an internet parts store. They looked good, nice Honda label box etc.but only lasted 20,000 miles! Obviously counterfit. Since I always put my old pads in the box I get with the new pads I was able to examine the counterfit box and pads. Very subtle differences upon careful examination.
So now I only get pads from dealer and carefully compare to old packaging and pads.
Factory pads give good rotor life and work very well for my driving.
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 10-14-2024, 09:02 PM #25
Grafixx01 Grafixx01 is offline
Grafixx01 is on a distinguished road
Originally Posted by Jbellah View Post
Suggestions on brake pads OEM OR?
I've always used PowerStop... The ones rated for Truck & Tow.
I had them on my 2009 Tahoe that had a lift and 35" tires and I use them on my 2019 4Runner SR5P with a lift and 35" tires. I pair them with their slotted and drilled rotors.
I'm now trying to find someone in Northern Alabama who will actually turn the rotors so I don't have to buy new ones next time I need new pads.
Grafixx01 is offline   Reply With QuoteReply With Quote
brake , oem , pads , suggestions
Need help: rear brake piston stuck (pressed brake with pads out) slide531 5th gen T4Rs 5 11-10-2021 09:19 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Tundra brake caliper leaked brake fluid all over pads, replace or clean pads? Srt4runner 3rd gen T4Rs 8 10-30-2015 12:42 AM
brake pads. my brake pads r squeeling. want to know if Thermo quiet will work spartacus 3rd gen T4Rs 4 04-21-2012 08:00 AM
