Old 10-12-2022, 05:45 PM #1
erocker14 erocker14 is offline
erocker14 is on a distinguished road
Tire sensor light on
2012 T4R Trail
My tire sensor light and apparently according to discount tires i have 3 sensors that are out. My tires are all good just that dang light. I dont wana spend $65 per tire to replace the sensors. Will be trading it in soon. And I dont mind the light.
MY question is will my 4runner pass an inspection with that light on.
My inspection is due. Maybe I can pull a fuse or something but wondering if that will do something to the computer that is connected when they do an inspection.
Thanks.
erocker14 is offline   Reply With QuoteReply With Quote
Old 10-12-2022, 05:54 PM #2
5thToy 5thToy is offline
5thToy is a jewel in the rough 5thToy is a jewel in the rough 5thToy is a jewel in the rough 5thToy is a jewel in the rough
TPMS light will not result in failed safety inspection in Texas.
Texas Department of Public Safety - Inspection Criteria for the Annual SAFETY Inspection
5thToy is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 10:28 AM #3
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
You will not fail inspection because of TPMS Light.
Also, I am not 100% sure, but if your light is actually “on” and not blinking, I believe it means that tire (s) pressure is actually low; TPMS light will blink if one or all of TPMS sensors are malfunctioning (broken\low battery\ not communicating with TPMS module).
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: http://www.toyota-4runner.org/5th-ge...estion-50.html thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 12:32 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about
flyrv9's Avatar
I have a TPMS light on too; and have had it for a while now. Since I have a 2013 SR5 and TPMS battery life is around 7-8 years, I figure I have a bad battery - or more. There is no way in the SR5 to determine which tire it is. Poor design by Toyota. I just check with a tire gauge and call it good.
Old 10-13-2022, 01:07 PM #5
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I don't know if the 4th and 5th gens share some electronics but this is worth diving into: Write-up: How to Disable (Bypass) the TPMS
I did this on my 2007 because I too wasn't going to pay $65/wheel/x5 to replace the sensors.
It's a bypass that is reversible.
EDIT:
After a search I found this: 5th gen TPMS disable
1988 4Runner SR5- ~250k Miles and counting - 5 Speed
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 01:15 PM #6
flyrv9's Avatar
flyrv9's Avatar
It's getting so I don't notice the light now! I might get the sensors replaced when I get new tires, but that will be a while. Toyota's logic escapes me here. In the early 5th gens they don't make sensor values display and unless you have a Limited there is no sensor in the spare. The spare is the one value I'd want; since it's stored with the valve stem up.
Perhaps the guy that designed the infotainment system designed the TPMS system as well!
Old 10-13-2022, 01:50 PM #7
So true.
Old 10-18-2022, 05:30 PM #8
Thanks for the info. I did get my 4runner inspected no problem.
Old 10-18-2022, 05:31 PM #9
Tire pressure all ok. I will just manage the old school way with a tire gauge.
Dont wana give discount tires 65$ per tire.
Old 10-19-2022, 08:53 AM #10
Humble Leader's Avatar
Humble Leader is just really nice Humble Leader is just really nice Humble Leader is just really nice Humble Leader is just really nice Humble Leader is just really nice
$65 a tire seems like a lot. I got OEM sensors at $50 a piece Canadian, bought and programmed at toyota.
Old 10-19-2022, 10:15 AM #11
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
Mine blinks then turns solid every time I drive; I am not driving the original wheels/tires and haven't had it reset, so it will do the same if it's missing a reading.
Toffees is offline   Reply With QuoteReply With Quote
inspection , light , sensor , tire , tires
HELP: Steering Angle Sensor - Traction Light and Powersteering Light Jayhawk5G 5th gen T4Rs 0 09-17-2020 11:05 AM
4runner spare tire and sensor light ?? pacho 5th gen T4Rs 13 11-19-2013 07:04 AM
new tire pressure sensor, turning off light? elykoj 4th Gen T4Rs 6 05-04-2012 05:23 PM
Tire pressure sensor light JTTurner 4th Gen T4Rs 3 01-15-2010 06:39 PM
Tire Pressure Sensor - Spare tire Tdub 4th Gen T4Rs 3 09-01-2008 10:49 AM
