Originally Posted by Sempre Nissart
You can use both at the same time.
You just can't display both on the same screen at the same time.
Originally Posted by jp.vegas
You can, just change the audio source in the "audio" menu on the head unit. You can't however see the station/frequency display while running Waze on CarPlay or AA.
I did NOT believe you guys as I have tried to make this work many times to no avail.....But you were absolutely right. You can listen to AM, FM (or XM) natively and still see/use AA apps
However, it turns out the AA interface itself can get in the way, at least in my experience. Documenting here in case anyone else has the same issue....
What was happening for me is every time I would select AM (or FM) from the native audio source while I was plugged in and already running Waze or Google Maps via AA, the AM source would turn off and the AA would automatically start playing my Spotify or Podcast app instead. As I had these apps running on my connected device, for whatever reason, it was defaulting to them as an audio source. I unplugged my device (S21) killed both apps (Spotify and Pocketcasts), plugged back in and the issue was resolved.
Sorry for the bad info DoTheMath!
