Old 10-13-2022, 09:12 AM #1
atl300zx atl300zx is offline
atl300zx is on a distinguished road
Driverside Door Wont Lock from Remote or Button
My driverside front door doesnt lock when i use the remote lock (nor do i get a beep or the lights turn off on double click). It also doesnt lock when i use the button inside.
Its only that door. Has anyone experienced this problem or have an idea of what i need to replace?
TIA
(2018 TRP Off Road Premium)
2018 Off Road Premium -- Gobi Stealth Roof Rack w/ Ladder, 20" Toyota Black Gunner Wheels with Nitto Grappler Tires, Black Billet Aluminum Grille, Black Emblem Overlays, Black Crushed Oval Step Boards, OEM Painted Bumper Overlays
atl300zx is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 09:23 AM #2
grizz1925 grizz1925 is offline
grizz1925 is on a distinguished road
Is there any noise from the door? I had this problem when I took the inside door panel off to swap out speakers and forgot to snap back in the lock and handle cables. It was making a weird noise, wouldn’t beep or lights go off. I took the panel off and fixed the cables and problem solved. I would start by removing the door panel.
grizz1925 is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 09:57 AM #3
131North 131North is offline
131North is on a distinguished road
I used to have that problem frequently on my Tacoma, but it hasn't happened on the 4Runner, however maybe they share components? The motor that actuates the lock was inside of a small white plastic subasssembly, and it used tiny little gears – like the ones on a small toy car. From time to time the grease they used in that subassembly would thicken in viscosity and bind up the mechanism to the point that the door would only lock/unlock with the key. I never replaced it, as taking it apart and cleaning/regreasing seemed to solve it for a time. Just thought that was worth sharing, in case that's what's happening to you.
131North is offline   Reply With QuoteReply With Quote
Old 10-13-2022, 02:00 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Door lock actuator failures are a common problem in our 4Runners. The only fix is to replace the actuator motor. Not a big job, but it does require removing the interior door panel. There are a few threads on this that have good explanations with pics. Do a search on drivers door lock actuator repair by mbumpus11. He posted a detailed thread on how to remove the door panel (there is a separate thread in the stickys for panel removal too). He also includes a link to the replacement motor.
There is another thread on door lock actuator failures by user tekewin that has good info that will come up in a search.
These threads are from 2015 and 2017.
Old 10-13-2022, 08:13 PM #5
There is no noise. I’ll take off the panel tomorrow and take a look. Sucks it happened so quickly and on the front driver door.
Old 10-14-2022, 06:23 AM #6
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
As others have said, likely the door lock actuator.
Hardest part is taking the door panel off. you-tube can help you.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 03:45 PM #7
taildragger taildragger is offline
taildragger is on a distinguished road
I had the same issue on my front passenger side about a year ago and it was the door lock actuator. Ordered a replacement off amazon and installed it in about 30 min. Was a fairly easy swap
taildragger is offline   Reply With QuoteReply With Quote
Old 01-18-2024, 11:01 AM #8
Dzldust Dzldust is offline
Dzldust is on a distinguished road
Revisiting this thread instead of starting a new on,
Anybody here notice this problem start in cold weather?
I’m in Florida and we have had an unusual three days of very cold weather and my 21 4runner has been intermittent with the drivers side lock working from fob, all other doors work but drivers door. For the guy that used the Amazon door lock actuator, has it been a good part for you?
Dzldust is offline   Reply With QuoteReply With Quote
Old 01-18-2024, 11:07 AM #9
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
My passenger door does this randomly, definitely the actuator going bad. Had this issue on my 4th gen as well
button , door , driverside , lock , remote
Door switches lock, but wont unlock Thallihan 3rd gen T4Rs 2 05-29-2021 02:03 PM
TRDORP - Possible to roll up liftgate window with lock button on remote? The_Mickstar 5th gen T4Rs 5 07-16-2018 12:45 PM
4r 1988 lock door button broken/missing SomeDay Classic T4Rs 18 07-15-2017 01:58 PM
keyless entry problem...front door wont lock NickS040 4th Gen T4Rs 1 02-17-2010 03:02 PM
pwr door lock button NITO98Limited 3rd gen T4Rs 3 09-21-2008 11:33 AM
