Old 10-15-2022, 12:35 PM #1
JWM816 JWM816 is offline
JWM816 is on a distinguished road
Angry Map lights shorted??
Hello,
I am doing a LED upgrade to the interior lights. I was finally able to get one map done and was working. Then on the second one I broke the bulb, in my rush I just used my pliers to pull from the middle and I saw a spark...
Now neither map light works. The dome is still on, I thought they were on the same fuse?? The fuse that says dome is fine. Not sure if I shorted something out on the board or what...hope not!
Everything else on the overhead console is working. The little LED that turns on when you have your headlights on, all the crawl control settings.
Hoping someone may have some insight.
Thank you!
2018 TRD OR Magnetic Grey
So far all form and no function mods...
On the lookout for a PRO front valance...
JWM816 is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 12:37 PM #2
agoff71 agoff71 is offline
agoff71 is on a distinguished road
Probably blew a fuse.
Sent from my moto g stylus 5G (2022) using Tapatalk
agoff71 is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 01:40 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about
flyrv9's Avatar
There are a few threads here covering this and the bad outcomes that result. You might luck out and have it just be a blown fuse. Others have found they shorted out one of the control computers which are not cheap to find and replace.
Always disconnect the battery before doing any type of electrical work to help avoid short circuit damage.
I would start by checking all fuses in both fuse blocks (with battery disconnected) by pulling each fuse and checking with a meter. Check one at a time and replace or re-install before moving to the next one.
Old 10-15-2022, 01:57 PM #4
Was watching other videos and no one else was...then became complacent...
Curious what control computers would operate along with these lights and if I can expect to run into some other issues later. So far everything else is working...guess I will have to get a meter...
I am not able to find any of these threads that have covered this either.
Old 10-15-2022, 02:34 PM #5
flyrv9's Avatar
flyrv9's Avatar
Well the computers involved will depend on what circuit (if any) was damaged. I would check all fuses first and after making sure all are good and reinstalled correctly; reconnect the battery and see what works and what doesn't.
Toyota labels fuses for the main circuit they control or protect. Sometimes other things are also involved with the same fuse. Without going through all the wiring diagrams, it's easier to know all your fuses are good and then see what works and what doesn't and go from there.
Once all fuses are good, I would put everything back the way it was until everything is working again. I would also check the sockets or bulb clips to see they are not bent or damaged and that bulbs fit correctly. Then start your LED swap over again. I'm guessing you had no lighting issues to begin with.
Getting a meter is a good place to start. Fuses can look good and still be blown. If you need help using a meter, let me know and I'll run through the basics with you.
Old 10-15-2022, 02:44 PM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Related to issue in the future:
When trying to replace the Map Light Bulbs, use a piece of plastic fuel line or clear tygon tubing that fits over the bulb tightly to remove these bulbs. Don't use pliers!
Just a heads up!
Best Regards,
Saker
Old 10-15-2022, 02:49 PM #7
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Just a heads up!
I've used tape in the past with success too. Just adding to your list of simple tools that won't risk shoring something out.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-15-2022, 03:00 PM #8
flyrv9's Avatar
flyrv9's Avatar
In relation to other threads involving issues caused by not disconnecting the battery before doing electrical work - my search (just now) didn't come up with anything. I've searched this issue before and remember at a couple of threads that didn't go well because of short circuits caused by working with power on or battery not being disconnected.
I remember these threads, but don't know why they don't now show up in a search. I did notice that the search function is now "google enhanced" which appears to result in lots of stuff unrelated to what I searched for! Perhaps that's why.
Old 10-15-2022, 05:12 PM #9
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Fuse usually not triggered by map or dome light mishap. My CarTrimHome cheap dome LED melted whole assembly and nearly caught rig on fire but did not blow the fuse. I was lucky to salvage integrated dome light switch because it is directly wired in and has no connector.
<<<< is offline   Reply With QuoteReply With Quote
dome , fuse , lights , map , working
Shorted ABS Wire? Zero0575 4th Gen T4Rs 4 09-18-2020 11:30 PM
Shorted something... Brilliant 3rd gen T4Rs 5 11-19-2011 02:54 PM
shorted wire after LED install hotskillet98 4th Gen T4Rs 0 10-13-2008 10:57 PM
EFI check connector shorted? prodigy2k7 Classic T4Rs 17 01-09-2008 08:56 PM
