Old 10-17-2022, 10:59 AM #16
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by MAST4R View Post
Yeah, I mean, with one, stuff can happen, but both?
On one of the several rear spring changes in my hot AZ garage, I forgot to undo the rear sway bar links...so ended up with one new link and one that is a little bent but ok.
Is it possible you did something that overstressed both sides at once?
It's definitely possible I did something, but I'll be damned if I know exactly what it was. About 6 weeks ago I was on some flat straight trails and possible going faster than I should have been... That being said I haven't been on a trail in about two weeks so whatever was the final blow that caused one or both to finally give was from driving around town.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 11:05 AM #17
comtn4x4's Avatar
comtn4x4's Avatar
Originally Posted by jbtvt View Post
Wild. Never seen this on any gen although I did lose a threaded rear trailing arm on a '99 camry once 10-15 years ago. Poly bushings are usually stiffer than rubber and that one looks really tight in there, so the lack of flex is probably what did it. Also want to make sure your vehicle is at ride height when you install something like this, but even if it was, if things can't move the way they were designed to something is gonna give.
I agree the bushings seem to be the only area of difference from stock. I use the Stongflex polyurethane bushings that Sonoran Steel recommends. I'll be receiving the new arms Wednesday and I'll get some photos and see how tight they are. The additional concern this now brings up is that the same bushings are on my lower control arms
Old 10-17-2022, 11:10 AM #18
comtn4x4's Avatar
comtn4x4's Avatar
Originally Posted by Xtremluck View Post
There is definitely something going on here. Maybe those upgraded bushings were too stiff and eventually fatigued the OEM links to the point of failure? I'd personally would just go OEM with stock bushings as a fix for this.
I agree the bushings seem to be the only difference from OEM. I'll investigate and report back
Old 10-17-2022, 11:24 AM #19
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Can't imagine the bushings you used had anything to do with your failure. Those bushings are designed to allow rotation type movement whereas the stock bushings are clamped solidly in place and movement is by torsionally twisting the rubber inside the steel bushing cup.
How did you remove your old bushings? Did you use heat in your removal process? If so, you could have used too much and caused metallurgical damage to the arms since the picture shows the failure appears to be at the weld.
Just a thought.
I bought some new OEM style upper arms for my '03 and cut the bushings out and installed Super Pro bushings, so I didn't use any heat.
So far so good, but I don't off road.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-17-2022, 11:36 AM #20
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Rockauto
Mevotech
$36 each.
Arms were thicker than oem on the set i installed on my 4th gen.
Couple years, no issues.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 11:38 AM #21
comtn4x4's Avatar
comtn4x4's Avatar
Just a thought.
I think you're onto something here. I didn't do the bushings myself, I had a shop do them. I seem to remember they had a hard time getting the old ones out. I don't remember if they said they used heat or not but it seems likely. It was about three years ago so it's a bit fuzzy
Old 10-17-2022, 11:48 AM #22
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Holy hell. I'm gonna have to go crawl under my truck and look at mine now lol
You got any pictures of the other side showing where the weld broke off?
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 12:25 PM #23
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
Given all the mods to the truck, my guess is you have way more articulation than stock thus the trailing arms can be operated well outside of their design limitations. From looks of it, they twisted too far and simply snapped.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 12:38 PM #24
comtn4x4's Avatar
comtn4x4's Avatar
I'll get some better pics as I go through the replacement process
Old 10-17-2022, 12:39 PM #25
comtn4x4's Avatar
comtn4x4's Avatar
This is very possibly it. The only thing I find odd is that it hasn't happened to anyone else? I don't think my truck had better articulation than others?
Old 10-17-2022, 12:51 PM #26
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
I've seen bolts back out but never the upper rear control arm shear. My only assumption would be that it was somehow damaged during removal of stock bushings and/or installation of new bushings...or maybe a weird combination of things previously listed
blksubykid is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 02:02 PM #27
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Yeah don't drive it like that at all. The only thing keeping your axle attached to your vehicle is your driveshaft at this point, hence the shuddering.
Once the driveshaft snaps you'll lose shock shafts, sway bar mounts, panhard bar, the entire axle housing... I've seen it happen to a 3rd gen on a trail, he posted on here years ago.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 02:30 PM #28
comtn4x4's Avatar
comtn4x4's Avatar
Thanks for confirming. I'm not driving it now until I get it repaired. Hopefully the 10 miles I drove it didn't do any damage
Old 10-17-2022, 02:47 PM #29
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
while those bushings probably allow for pretty drama free rotational movement (unless their bolt got REALLY torqued down tight), i wouldn't be surprised if those links sheared from binding in axial rotation (think of articulation, one wheel stuffed and the other at full droop). without a certain degree of give the only thing left to twist is the metal shaft itself.
i don't know the durometer of these bushings compared to other aftermarket choices, but its a problem that can rear its head in other applications, such as sports cars, where stock bushings with engineered-in-compliance are replaced with performance bushings that are too stiff, which then cause bind which gets worse the further through the travel range the suspension cycles.
really glad it failed in a mostly drama free fashion for you....that could have been a Code Brown for sure.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 06:20 PM #30
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Great Post
Poly bushings are primarily for single axis use only.
Often the poly itself will split and crumble.
When more axis are involved a heim type joint is much better choice for a performance mod.
seatia is offline   Reply With QuoteReply With Quote
miles , oem , rear , replaced , sheared
05 4RN Rear Upper Control Arms flaco21 4th Gen T4Rs 2 08-23-2022 03:51 PM
Upper rear control arms all the same? St Runner 3rd gen T4Rs 2 01-11-2021 10:25 AM
Upper control arms and rear coils Itssslance 5th gen T4Rs 23 12-18-2020 01:10 AM
Upper rear control arms dylan_n_00 5th gen T4Rs 4 07-17-2017 01:20 AM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
