Old 10-17-2022, 07:24 PM #31
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
The last poly bushings I installed required grease and even provided a small packet of said grease. I believe it was silicone based grease.
Do you know if grease is required here and was applied by installer?
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 08:30 AM #32
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Originally Posted by seatia View Post
Great Post
Poly bushings are primarily for single axis use only.
Often the poly itself will split and crumble.
When more axis are involved a heim type joint is much better choice for a performance mod.
thank you, and you said it more succinctly than me.
poly can be great in something like a sway bar or shock mount.
in a pillow-ball or control arm mount, you definitely need to be careful of bind, and aware that they'll likely wear out far quicker than a fresh rubber bushing. for off-road use i would never consider them, personally.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 09:04 AM #33
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
They Stongflex bushings that are on there came with a packet of silicone grease. I didn't do the install, but I'll assume they used it.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 03:37 PM #34
DigitalVex DigitalVex is offline
DigitalVex is on a distinguished road
I'm going with no grease and 150+ lbs. ft of torque on those bushings.
Basically made it a solid upper link on the axle side with no up/down or flex. Metal finally gave at the weakest part.
Make sure you watch or trust your installers, lol.
Good luck out there!
DigitalVex is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 04:07 PM #35
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
You added the Strongflex bushings prior to the upper links that broke? If so, I would question the install as DigitalVex mentioned.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 04:30 PM #36
comtn4x4's Avatar
comtn4x4's Avatar
Yeah I think that's it. The bushings have been on for about three years. I'm going to pull the old ones off tonight and I'll get a better look. New ones arriving tomorrow
Old 10-18-2022, 05:35 PM #37
Exactly, this. Both sides failing after installing these bushings is no coincidence.
Old 10-18-2022, 06:52 PM #38
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Let the record show I was the first one to suggest this and was quickly shot down
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 08:02 PM #39
no grease on poly? it wouldve squeaked like crazy. and to last 3 years? idk. could've been a freak thing. and nobody did anything wrong (except maybe poor driver mod) lol
Old 10-18-2022, 08:44 PM #40
Good point - she’d be a squeaker.
Didn’t see the 3 years comment until now.
But to his point, the significantly stiffer poly bushings will increase the peak and average stress in the rods. Maybe enough so to push them past the fatigue limit.
I would go back to stock bushings and rods or stay poly and acquire more robust rods.
Old 10-19-2022, 09:36 AM #41
comtn4x4's Avatar
comtn4x4's Avatar
Update
Ok got the UCA's off last night. The more rear bolts on both were very rusted but but came free without any drama. The forward bolts were easy to remove and had much less rust. I doubt they put a torque wrench on them but I also wouldn't say they were way over torqued. (Spec is 59#) All joint were able to be removed by hand without any tools and had reasonably good movement. I doubt they weren't greased at all, however they weren't greased how I would have done it. (As was said earlier if they weren't greased they woulda squeaked like crazy.)In their defense the packet of grease that came with them was relatively small. Let's remember these were on for 3 years, this wasn't an install the bushings and instant snap scenario.
From the looks of the snapped area of the arms it appears one snapped then the other gave at a later time. The arms themselves do not appear to have been in contact with anything causing them to snap. I'm not experienced with welds so I'll let someone else analyze that but the ends of both appear pretty flat to me, so maybe the weld gave? I think the idea that the installer over heated the arms removing the old bushings is at least a strong contributing factor if not the sole reason.
I attached pictures as well
Both Rear Upper Control Arms Sheared off? WTF!-uca-1-jpg  Both Rear Upper Control Arms Sheared off? WTF!-uca4-jpg  Both Rear Upper Control Arms Sheared off? WTF!-uca2-jpg  Both Rear Upper Control Arms Sheared off? WTF!-uca5-jpg
Old 10-19-2022, 09:40 AM #42
comtn4x4's Avatar
comtn4x4's Avatar
If anyone knows the part number for the bolts I would appreciate the help. The forward bolts are different than the rear bolts. When I look in the Toyota parts catalog this doesn't seem to be the case. It's possible the installer swapped out the bolts.
The only bolt part number I can find is 90119-14040
The nut I think is 90178-A0058
EDIT:
I think I need the following parts:
90119-14040 2each for mount to axle
90105-12340 2 each for mount to frame
90178-A0058 not sure about this, definitely 2 of these maybe
Thanks in advance
Old 10-19-2022, 01:58 PM #43
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Yes, the bolts are definitely not threaded all the way to the head, the other bolts are correct.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-19-2022, 02:02 PM #44
comtn4x4's Avatar
comtn4x4's Avatar
Thanks, yeah I was thinking they might've cut the old ones off
Old 10-19-2022, 05:47 PM #45
this reaffirms my comment....buy one aftermarket upper with upgraded heims. and see how it feels. you wont have to worry about contacting the fuel tank at full droop ;)
since it looks like one broke a while before the other one.
i DO NOT recommend buying from PRG as his customer service is absolutely atrocious BUT, he knows suspension.
FJ/4 RunnerGX470 4-Link KitThis is our 4-link Fj and 4 Runner rear link kit. This kit elliminates the driver's side upper link and is 100% direct bolt-on. No need to drill out holes or run custom bolts. Because our bearings do not have slop like rubber or urethane, there is no binding at all through the full range of movement. Zero side deflection, zero axle wrap and 100% free movement vertiacally and through full articulation. Becasue we use no urethane, there are no squeaks either and no messy zerk fittings. The lower links are 1.75" dia x .120 wall DOM (.250 wall on request and for more $$), the upper link is 1"x .250 wall and the panhard is 1.25" x .250 wall. The upper and panhard bar use left and right hand threads to make adjustments super easy, but we do send these out adjusted to the stock dimensions so you can simply bolt them on and be on your way. The lower links use FK 1" teflon-lined uniballs and FK 1x1.25" 3-pc teflon-lined heims in right hand thread (all of the bearings (heims) we use are NOT the shitty 2-pc Chinese heims that most offroad shops use. If someone says Heims are noisey, they use garbage bearings...GOOD heims are quiet). The upper link and panhard use FK 3/4 3-pc telon-lined heims. All the bearings are readily availble through many vendors, as well as us, should you need replacement parts in the future.Tubes are shown in RED but can also be plated in BLACK. Typical build time is about 10-15 working days. Why a 3 link and panhard vs 4 link and panhard...simple...it works better. The factory uses soft rubber bushings and a sway bar, there is a certain amount of "bind" built in to the OEM geometry...those bushings are also really cheap. Switching to this style of geometry has ZERO bind in the full usable range of movement and this allows for less stress on all the chassis mounting points as well as more life from the bearings. It simply costs more to do this. And any aftermarket 4-link w pahard bar kit that uses bearings at any pivot point is hurting the chassis and decresing flex and ride quality. | PRGProducts.Com
for the lazies who wont click a link .....
""Why a 3 link and panhard vs 4 link and panhard...simple...it works better. The factory uses soft rubber bushings and a sway bar, there is a certain amount of "bind" built in to the OEM geometry...those bushings are also really cheap. Switching to this style of geometry has ZERO bind in the full usable range of movement and this allows for less stress on all the chassis mounting points as well as more life from the bearings. It simply costs more to do this. And any aftermarket 4-link w pahard bar kit that uses bearings at any pivot point is hurting the chassis and decresing flex and ride quality.""
edit: wow that URL is weird
miles , oem , rear , replaced , sheared
05 4RN Rear Upper Control Arms flaco21 4th Gen T4Rs 2 08-23-2022 03:51 PM
Upper rear control arms all the same? St Runner 3rd gen T4Rs 2 01-11-2021 10:25 AM
Upper control arms and rear coils Itssslance 5th gen T4Rs 23 12-18-2020 01:10 AM
Upper rear control arms dylan_n_00 5th gen T4Rs 4 07-17-2017 01:20 AM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
