Old 10-19-2022, 12:03 PM #1
Mike Beyers Mike Beyers is offline
Mike Beyers is on a distinguished road
Spark Plug change problem
Well, chalk this up to "things that only happen to me" but I'm sure this has happened to someone. When removing the tube between the 2ndary air valve, and the exhaust manifold to access the spark plugs on the drivers side (2016 SR5, 106K, figured it was close, and it was a BEAUTIFUL day, so I'd do them) I broke off one of the studs at the exhaust manifold end. Yes, I had hit everything liberally with Kroil, and this was the ONLY fastener that gave me any trouble. In fact, it didn't really fight me at all, it just BROKE. I was using a small 1/4 drive ratchet, and snapped it off REALLY easily. I put a clamp in place temporarily as I try to figure out how to remove the broken piece. Its really cramped, and getting in there with any type of drill will be tough. Anyone ever had to do this?
Spark Plug change problem-4runner-clamp2-jpg
Mike Beyers is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 12:15 PM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Suggest maybe:
3.5 Amp 3/8 in. Variable Speed Close Quarters Drill
Small drill bits, more Kroil, easy outs and patience!
And a small source of directed heat, controllable.
Master Appliance MT-70 Butane Torch - Torch Lighter, Self-Igniting Butane Torch Lighter, Flame Temp up to 2500F, Adjustable Flame, Butane Refill - Power Soldering Accessories - Amazon.com
Best Regards,
Saker
Old 10-19-2022, 01:16 PM #3
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Have not had that specific issue happen to me, but the driver's side is always a PITA. I've had the internal flap or vane on the air valve break. Twice I've had wires come loose or out of the back of the harness plugs over there requiring replacement or repair. I dread that side, but somewhere here is a video of an 11-year old girl who does the job easily.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 01:18 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Right angle drill, or right angle drill attachment should get in there. Small drill bits, like Saker mentioned, are threaded on one end and screw into the head of a right angle drill attachment. They take up much less room than a chuck. I've found heat seems to work better than Kroil like products; but can't hurt to use both. Heat only if you can do it safely and not fry nearby parts!
If you have trouble finding right angle drills and bits, look into aircraft supply companies that cater to the homebuilding crowd. Aircraft Spruce and Wicks aircraft supply are two.
Old 10-19-2022, 03:22 PM #5
blksubykid's Avatar
blksubykid blksubykid is offline
blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice blksubykid is just really nice
blksubykid's Avatar
I backed out one of the studs when I removed the passenger side...fortunate not to snap one.
GL!
blksubykid is offline   Reply With QuoteReply With Quote
Old 10-19-2022, 04:27 PM #6
That drill might be just the thing. And who doesn't need another tool?! I will also look into heat!
Thanks!
Old 10-19-2022, 04:29 PM #7
It is indeed a pain! I think the 11 year old does the plugs on a pre-air-injection model. Nothing to move!
Old 10-19-2022, 06:32 PM #8
Damn, all this time I was really feeling inadequate. She was still pretty good.
broke , exhaust , fight , manifold , spark
V8 spark plug change report Atlanta_man 4th Gen T4Rs 11 02-15-2017 01:32 PM
Spark plug change out ? tmaxx13 3rd gen T4Rs 23 12-05-2012 03:36 PM
questions about spark plug change bjballa41 3rd gen T4Rs 17 04-15-2012 10:08 PM
04 T4R Spark Plug Change cgarrett5119 4th Gen T4Rs 5 03-08-2012 04:48 PM
spark plug change 91bulldog Maintenance/Detailing 3 11-25-2005 02:24 AM
