Old 10-28-2022, 03:20 PM #16
Longv Longv is offline
Longv is on a distinguished road
Another option VoltageBoosterPRO
Longv is offline   Reply With QuoteReply With Quote
Old 10-28-2022, 06:30 PM #17
Ripper238's Avatar
Ripper238's Avatar
I already purchased the Arclight Booster, but that one looks almost exactly the same. Less the OEM/Off charging which could come in handy.
Old 10-29-2022, 10:03 AM #18
Ripper238's Avatar
Ripper238's Avatar
Curious. Any reason to upgrade my alternator for the Arclight Booster for long term durability?
Should i leave it at the highest charge?
Old 10-29-2022, 03:36 PM #19
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
I don’t see any reason to upgrade your alternator for long term durability. I haven’t heard anyone pointing to an alternator failure directly related to the ArcLight booster. I set mine to the boost setting (the low setting of the two) and drove it as I always do. 4 years later… all good!
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 10-30-2022, 10:41 AM #20
Ripper238's Avatar
Ripper238's Avatar
Thank you.
Ill probably set it to the regular boost setting too and use the extra boost when I am overlanding where i may idol to get some extra juice for over night.
My ride to work is only about 15min each way, but I am sure that will be fine with my long rides on my day off. Been manually boosting it with a charger for a year now which was fine but this should be much better when I'm on the road. Almost seems getting an AGM and not adding a booster is a waist.
Old 10-30-2022, 11:25 AM #21
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
For new AGM owners:
I have 2 starter batts and one Deep Cycle/Starter batt as house power for the 5th gen. They do not like to sit, and they don't like short trips. Having a smart charger is a good way to keep your battery investment in good condition. I top mine off with it once or twice a month even though I run the boosters. If you're averaging 50 to 100 miles a day, that might be enough to keep it topped off with the voltage booster.
X2 on the ArcLight, well made unit. I have a Dirty Parts booster on my 4th gen and it's been working well also. Just make sure you use one with the 7.5 amp fuse. The GM diode mod doesn't have the fuse, and it would be a slim chance, but it could cause problems in a collision, or other unexpected situations. And like was mentioned earlier, the voltage may be weak or inconsistent.
Sorry to hear about Northstar, didn't they make the X2?
I hope Odyssey keeps up the quality in that line. Expensive but they have been trouble free for years, with lots of abuse/vibration offroad.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 10-30-2022, 11:45 AM #22
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Yes Northstar made the X2 line for Batteries Plus. The purchase was finalized late '19 so it's been a few years now. I haven't seen any conclusive information, however, it appears the X2 line may still be made in the Northstar plant.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 10-30-2022, 11:54 AM #23
Real Name: Brett
Real Name: Brett
From what I understand, for awhile Odyssey had some QC issues right after they opened the Mexico plant. I haven't heard anything bad for a few years now.
So hopefully they are putting out the quality that they did when they made a name for themselves.
The X2s are stupid expensive, but I've had my share of batt issues, so it was worth it to me. Most people will be fine with an economical choice in batteries, but in the performance offroad and marine industry, they take a beating.
Old 10-30-2022, 05:21 PM #24
comtn4x4's Avatar
comtn4x4's Avatar
I wasn't aware Odyssey had a plant in Mexico... however, Optima does and they have had issues since they moved production there?
Old 10-30-2022, 05:46 PM #25
Real Name: Brett
Real Name: Brett
Yes Sir, I was mistaken. I was thinking Optima. SMH...
Old 11-04-2022, 09:51 AM #26
Ripper238's Avatar
Ripper238's Avatar
Installed ArcLight booster and set to standard boost. 14.3+ at start up and after 15min ride dropped down to ~13.6. Getting ~ .5V of extra power just like it suggests.
Old 11-04-2022, 11:32 AM #27
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
Another option: Full River and Full Throttle Batteries. Batteries - FT Series | Fullriver Battery
They are expensive, but definitely well made with quality stuff. I have started using them in our fleet for ambulances and fire trucks, and we're looking to use them in our reserve police vehicles to help prevent dead batteries.
I'm going to talk to them next week when they deliver some more to me about the maintenance, because as of right now we're not changing anything about how we keep them charged.
What I do know is that flooded cell batteries won't last on the shelf for more than a few months (or in a reserve vehicle) but these will maintain their charge for up to a year and a half. I'm at least sold on trying them out for our applications. It's only been about 6 months so far that we've been using them, so time will tell. But they appear to be what the Northstar's used to be in quality. Even the old days of Optima, before they moved their manufacturing and the quality tanked.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 11-05-2022, 10:53 AM #28
Ripper238's Avatar
Ripper238's Avatar
Reading over AGM charging voltage requirements the 14.3v let alone the 13.6v are not enough to charge an AGM battery?
I have an ODYSSEY 24F AGM so probably not a big deal but it seems the lower boost setting will do next to nothing and the over boost may push it too close to 15v.
I guess its better than what it was?
Old 11-05-2022, 01:46 PM #29
AGM Battery GM Voltage Booster
Like a couple of us above have said above, just set it to the low voltage setting and forget it. You can bump it to the higher boost setting in the winter if you like and that should be fine. That way you are only having to flip the switch twice a year and not going back and forth constantly. I know more than 50 people who I overland/camp with that have used their voltage booster exactly as we have stated. If you want to be particular here are some charging voltages. On regular basis 12V deep cycle AGM batteries, float charge voltage is 13.5V~13.8V, cycle charging voltage is 14.4V~15.0V. Don’t overthink it. Lower boost in summer and higher boost in winter.
Old 11-05-2022, 02:26 PM #30
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Originally Posted by TRD PANTHER View Post
Which make and model AGM battery did you guys go with?
Panther,
I have a dual Battery system, The primary is a Odyssey 34R, which fits into stock battery tray, (No cabling mods needed just add the bottom spacer sold separately).
The secondary Battery is an Otima Marine dual purpose. Only because it fits into the shrock works battery tray. They can be connected Via a Blue sea ACR. But I haven't had the need to flip the switch. I charge both batteries with a CTEC 7002 charger set on snowflake. this keeps them topped off. I must also mention that my truck is not a Daily Driver and garage kept.
signature not available
Rack is offline   Reply With QuoteReply With Quote
agm , alternator , battery , booster , voltage
"Voltage Booster" for 31M AGM Battery ADVnut 5th gen T4Rs 400 02-17-2023 07:11 PM
2020+ Voltage Booster AND 5th gen T4Rs 12 02-24-2022 03:13 AM
SOLD HKB Electronics MK2 Voltage Booster for AGM Batteries ebadai98 For Sale: T4R Items 2 10-31-2021 06:37 PM
Overheated alternator from HKB voltage booster CarlosV 4th Gen T4Rs 4 09-17-2021 07:42 PM
