Old 11-05-2022, 02:42 PM #31
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Originally Posted by comtn4x4 View Post
I wasn't aware Odyssey had a plant in Mexico... however, Optima does and they have had issues since they moved production there?
Over the years I have had no problem with the Optima Batteries, In my Boat they lasted Nine Plus years.
Recently I noticed some corrosion on the negative terminal of my aux Optima battery in my 4R. In the Optima brochure they state that Optima's are sealed and won't cause corrosion. I cleaned it up and a month later it was back. The battery was 5 years old so I replaced it with a new Optima.
I took a good look at the negative post and noticed it was cracked, the post are hollow. causing gas to leak out and cause the corrosion.
Then I remembered I had installed a quick connect for my charger to the post using Military battery clamps and evidently over tightened the compression bolt cracking the post. lesson learned.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 11-06-2022, 10:26 PM #32
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by Longv View Post
Another option VoltageBoosterPRO
Looking for the newer versions, so I posted this link in case someone missed it.......
Voltage Booster for 20-22 T4R's to optimize your AGM battery
Best Regards,
Saker
Old 11-07-2022, 12:09 PM #33
97BlackAckCL's Avatar
97BlackAckCL 97BlackAckCL is online now
Real Name: Chris
Real Name: Chris
I had 2 Optima Yellow Tops in a row that were absolute garbage after having working ones for over a decade that were bullet proof. Both came from the Mexico plant. I switched to Odyssey and never looked back
97BlackAckCL is online now   Reply With QuoteReply With Quote
Old 11-07-2022, 07:49 PM #34
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Originally Posted by Token_Indian View Post
Thanks for the feed back and information. So its safe to say the Arclight voltage booster is the way to go to keep the AGM batteries topped off. Has anyone had any issues with the arclight booster, overcharging the battery or would the fuse pop protect it from damaging the battery?
Hi Token_Indian,
The fuses will NEVER protect aganst High Voltages, but are designed to blow if High Amperages are sensed above 10%!! Extremely High Voltages will damage Compu Networks, lighting, appliances...etc, so we'v gotta watch for that!
~rig~ Cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 04:10 PM #35
Token_Indian's Avatar
Token_Indian Token_Indian is offline
Token_Indian is on a distinguished road
Originally Posted by rigtec View Post
Hi Token_Indian,
~rig~ Cheers!
Thanks Rig!
That is very interesting. Do you use an OBDlink to check voltage and make sure it is in optimal range or is there any regular maintance that you inspect?
I really want to get the AGM battery but Im just worried about upping the voltage and like you described "damaging the system, network, lights, etc."
Token_Indian is offline   Reply With QuoteReply With Quote
Old 11-08-2022, 04:51 PM #36
Real Name: Chris
Real Name: Chris
Thanks Rig!
The voltage tweaks are very minor, just changing the charging voltage of the alternator. I monitor my system with my radio and have seen no harsh spikes or issues in over 2 years. I too was skeptical especially of the GM diode, but I've been impressed with the higher voltage gained with the Arc Light circuit and I only run it on the first boost setting not the full on voltage boost (it has 2 settings)
Old 11-08-2022, 05:06 PM #37
Ripper238's Avatar
Ripper238's Avatar
Thanks Rig!
Rig was just answering you question about voltage and fuses and how fuses dont protect against votage but protect against amprage spikes.
Higher amprage would have to come from somwhereelse than the voltage booster to damage. The voltage booster only bumps by .5A - 1.0A which is nothing.
Arclight voltage booster is a good safe way to go to keep the AGM batteries topped off. Your other safe option is to get an AGM battory charger like the Noco Genius 2 Battery Maintainer. Its just anoying to do and doesint really work for my long term Overlanding.
I have been able to monitor my voltage through my head unit. Definitly works as advertised so far.
Old 11-09-2022, 05:22 PM #38
Will_4R's Avatar
Will_4R Will_4R is offline
Will_4R is on a distinguished road
Will_4R's Avatar
Would installing this in my 4Runner help charge the batteries in my travel trailer while driving? I have a dual AGM set up in the trailer that has a hard time charging up while driving, especially when under a load from the 12V fridge. The trailer has a three stage AGM charger in it (which is suppose to regulate the voltage), but for some reason it just isn't enough to do more than maintain their charge while driving. I also run an AGM in the 4Runner, so that's 3 batteries the alternator is trying to charge while driving. Maybe I just need a bigger alt?
2003, Sport, V6, 4WD
Overland Warehouse/Radflo 2.0 suspension, SPC upper control arms
2016 Trail Edition w/KDSS
Icon Stage 2 suspension, BFG T/A KO2 285/70/17, C4Fab sliders
Will_4R is offline   Reply With QuoteReply With Quote
Old 11-11-2022, 03:23 PM #39
Ripper238's Avatar
Ripper238's Avatar
Sounds like you have multiple AGM batteries and already have a three stage AGM charger. A bigger/better alternator sounds more appropriate. The voltage booster is for a simple upgrade to an AGM.
Old 11-22-2022, 05:14 PM #40
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Hello,
I am in the process of updating my main battery for the Runner and have read from multiple threads about the lack of voltage that comes from the stock alternator when upgrading to an AGM battery. Apart from getting an actual voltage booster it seems that the GM diode is a good substitute.
I am inquiring on those who have gone the GM route if they have encountered any issues with over charging the AGM battery or by increasing the voltage coming from the alternator if it lessens the life of the alternator?
I am not doing anything too crazy offroad, mostly 2-3 night camping, and I have been getting by just fine with the regular 24f battery, but I can get a decent priced 24f AGM for the same price. I dont have a fridge just yet and the only draws to the battery are mostly lights. Im just thinking in the future if I get an AGM battery that it would put extra stress on the alternator or does the voltage booster just boost the regular alternator capacity without overworking it?
Either way Ill be getting a quality battery. Thanks.
I already switched to AGM and am upgrading to the CS144 alt this weekend. No reason to do the GM booster
Originally Posted by TRD PANTHER View Post
Which make and model AGM battery did you guys go with?
Deka 9A34R
I plan on running two AGM batteries, start and house. Here's the thread I started after talking to Battleborn, Redarc, Blue Sea and a few others :
Charging and power storage project for my 99 4runner
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 12-08-2022, 12:14 PM #41
Magnetic's Avatar
Magnetic Magnetic is offline
Real Name: Doctor Magnetic
Magnetic is on a distinguished road
Magnetic's Avatar
Originally Posted by Ripper238 View Post
Is this correct place to buy Arclight Booster: Triple State Voltage Booster - 5th Gen 4Runner — ArcLightLEDs
Shows as "Sold Out" on their website...
Reserved for Powerful Insights, Witticisms and/or Merely Clever Clichés...
Magnetic is offline   Reply With QuoteReply With Quote
Old 12-09-2022, 01:38 PM #42
Ripper238's Avatar
Ripper238's Avatar
Shows 10 available today.
Just topped off my AGM and turned the booster up to max for the winter, So far so good. Though I think I may need to leave it at max since I drive so little during the week.
Old 12-29-2022, 03:29 PM #43
Anyone considering/do the GM Diode mod?
Odyssey AGM Battery and GM DIODE Mod for higher Voltage for Proper Charge
Old 01-01-2023, 11:54 AM #44
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
No. Diode replaces a fuse and offers no protection to that circuit.
<<<< is offline   Reply With QuoteReply With Quote
Old 01-01-2023, 12:50 PM #45
Ripper238's Avatar
Ripper238's Avatar
Arclight Booster has been doing its job if i drive an hour, so good there.
My only issue is I don't drive enough (25min a day) to fully charge the battery even at the max boost of 14.9v. I end up with 12.2v after a day or two of not driving, so it seems I may have a parasitic draw. lol
agm , alternator , battery , booster , voltage
"Voltage Booster" for 31M AGM Battery ADVnut 5th gen T4Rs 400 02-17-2023 07:11 PM
2020+ Voltage Booster AND 5th gen T4Rs 12 02-24-2022 03:13 AM
SOLD HKB Electronics MK2 Voltage Booster for AGM Batteries ebadai98 For Sale: T4R Items 2 10-31-2021 06:37 PM
Overheated alternator from HKB voltage booster CarlosV 4th Gen T4Rs 4 09-17-2021 07:42 PM
