Old 10-31-2022, 12:44 PM #1
emmantik emmantik is offline
emmantik is a jewel in the rough emmantik is a jewel in the rough emmantik is a jewel in the rough
How to tap into dome light
Hi all,
Just thought I'd share how I figured how to tap to the dome light since there is no other post about it. This is for wanting to have accessory lights to turn on and off with the dome light. For me, I added footwell lights to my 3rd row as there is no lighting back there for the kiddoes.
First off, I fished a wire from the rear right passenger headliner. The overhead grab handle would need to be removed first. I ran the wire down the B pillar and down under the footwell trim to the rear wheel well.
To remove the housing you can read about it in this thread;
Remove Dome Light Housing
Once you remove the housing there is a small block that houses the electrical. You can pry up at 4 corners with a small screwdriver to release.
Once off, there is a metal housing/cover that simply pops off - just pry up. I left it off after as I needed the extra space for wires/terminals.
You can see with the red and black wires shown which side will give you power and which is ground. You will have to use your creativity here on how you tap/connect to these points - I will leave that up to you.
So far it works like a charm! The lights I installed even dim with the dome light!
Hope this helps anyone looking to do something similar!
How to tap into dome light-1-20221029_085839_resized-jpg  How to tap into dome light-3-20221030_103224_resized-jpg  How to tap into dome light-4-20221030_103327_resized-jpg  How to tap into dome light-5-20221029_110755_resized-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 10-31-2022, 01:01 PM #2
I added a strip light to the upper part of the wheel well pocket. As you can see, there is an angled portion that gives the perfect direction to aim the light. Here is a shot of the end result.
How to tap into dome light-1-20221023_190237_resized-jpg  How to tap into dome light-2-20221030_164742_resized-jpg
Old 11-01-2022, 11:29 AM #3
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of
Real Name: Chris
Badass man, nice work
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, VR ECU Tune, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
Old 11-09-2022, 01:06 PM #4
I ended up doing both sides. I might change the strip lights (6" VLEDS) to Oznium 11mm LED flush mount bolts as I don't like seeing the light source - but the lumen output is great! LED bolts won't be as bright but I like the fact that I won't see them - just the light output. We'll see!
How to tap into dome light-1-20221108_171943_resized-jpg  How to tap into dome light-2-20221108_171954_resized-jpg  How to tap into dome light-3-20221108_172002_resized-jpg
Old 11-15-2022, 05:16 PM #5
Decided to change the LED strips for LED bolts. Bit more discreet and not super bright just enough for what I need it for.
How to tap into dome light-20221113_120840_resized-jpg
Old 11-16-2022, 12:44 PM #6
Real Name: Chris
Real Name: Chris
Love this, I like how it illuminates the trunk storage area and third row. Looks great!
dome , housing , light , lights , pry
Driver door light / dome light problem LRT 5th gen T4Rs 8 01-02-2020 10:25 PM
LED Map & Dome Light Mod!!! Fo_SheeZy 3rd gen T4Rs 43 12-01-2016 09:14 AM
WTB Dome Light for '03 SR5 Churchill Want to Buy/Trade 0 06-30-2015 06:52 AM
Map light wired to dome light? Lowriderman234 3rd gen T4Rs 2 09-03-2012 01:21 PM
personal light/front dome light bigred528 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 11-01-2010 01:30 PM
