Old 10-31-2022, 08:19 PM #1
kkqewl kkqewl is offline
kkqewl is on a distinguished road
TPMS question
I have 2021 TRDOR and I just swapped my summer tires and wheels with my winter set, both wheel sets are equpped with factory TPMS sensors.
After 15 minutes of driving around the sensors came to life and started to display pressures. However all pressure readings are off ( 4 psi to low ) as verified by a calibrated external pressure meter.
Do I need to reset / recalibrate the TPMS sensors with the tires inflated at the normal 32 psi for the system read correctly ??
kkqewl is offline   Reply With QuoteReply With Quote
Old 10-31-2022, 09:21 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about
flyrv9's Avatar
I would watch it for a while and if still the same (4psi low) on all wheels then just do the math (add 4 psi to the values posted) for the Winter. Or ignore the readings and just check with a gauge periodically. It's not worth the time IMHO to mess with it.
Old 11-01-2022, 12:07 PM #3
Ripper238's Avatar
Ripper238 Ripper238 is online now
Ripper238 is just really nice Ripper238 is just really nice Ripper238 is just really nice Ripper238 is just really nice
Ripper238's Avatar
Is your external pressure meter right? lol
My head unit measures air pressure and temp through the factory TPMS and it displays 2 PSI higher than actual external measured PSI. Which is fine.
Temperature will also effect your PSI warmer tire the higher the PSI.
Ripper238 is online now   Reply With QuoteReply With Quote
pressure , psi , sensors , tires , tpms
TPMS question MAG GRY TACO15 5th gen T4Rs 16 09-10-2022 04:08 PM
tpms question hankd 4th Gen T4Rs 10 08-06-2020 03:48 PM
A TPMS question adrtoy 5th gen T4Rs 3 01-17-2017 05:48 PM
TPMS question... Martinjmpr 4th Gen T4Rs 7 05-06-2013 09:10 PM
TPMS question 04_4runner 4th Gen T4Rs 2 02-03-2012 09:57 PM
