Old 11-03-2022, 02:11 AM #16
Rambo3500 Rambo3500 is offline
Rambo3500 is an unknown quantity at this point
Glad to see I’m not the only one. This topic should be elevated in the 4runner community so folks who off-road in their runners know to stay far away from SPC junk!!!
Rambo3500 is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 02:29 PM #17
Update: it was the ball joint. Shop said they used to be flawless up until around ‘14 when they changed the design and now apparently they’ve been getting more complaints from people running SPC’s.
Getting a credit towards Icons and will grease them religiously. Hopefully this solves my UCA woes. Aside from that everything about my lift has worked perfectly.
Old 11-04-2022, 03:13 PM #18
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
You’re not going to like Icons much better friend. Delta Joints are garbage as well. They wear out within a year of hard off-road use. I would just go with a reputable UCA with standard uniballs or a sealed ball joint
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 04:33 PM #19
SPC UCA’s quality going downhill
Man there must be a lot of non-off roaders who would’ve been better with a puck lift out there!
Shame that more people don’t use their runners for what they were designed for. Maybe then the market would shift away from producing Chineseum grade rubbish.
Old 11-04-2022, 04:41 PM #20
Are Total Chaos any better?
Old 11-04-2022, 06:12 PM #21
DigitalAviatorZ DigitalAviatorZ is offline
DigitalAviatorZ is on a distinguished road
let me share something with you
UCA's True Functions and Misconceptions | Toyota Aftermarket UCA Part 1 - YouTube
UCA Designs vs Your Build | Toyota Aftermarket UCA Part 2 - YouTube
DigitalAviatorZ is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 07:15 PM #22
Great videos! Aftermarket UCA’s were needed in my case due to 3” of lift, but my goal is also as little maintenance as possible (don’t have my own garage or space to rip them apart for greasing and what not) so I may just have to budget for bushings and ball joints being more frequent wear items due to off road use.
Old 11-04-2022, 10:34 PM #23
Catahoulabulldog Catahoulabulldog is offline
Catahoulabulldog is on a distinguished road
Fabtech
Catahoulabulldog is offline   Reply With QuoteReply With Quote
Old 11-04-2022, 11:40 PM #24
Jeremy556's Avatar
Jeremy556's Avatar
Were they ever good? I had some back around 2013ish and threw them away within a year after several upper ball joint problems.
I've been running TC since getting rid of my SPCs in about 2014. They are trouble free, but require maintenance, of course. I usually replace the uniballs every 18 months or so and have replaced the bushings once in 200k miles.
Old 11-05-2022, 03:59 AM #25
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Depends on what you prioritize.
Total chaos UCA are made of Chromoly, with built-in or non-adjustable caster and utilizes a uniball. So basically, TC makes well designed and tough UCA.
They do require a bit of maintenance, and if you neglect the maintenance they can get noisy, clunky, and rusty. However, due to the simplicity of their design and the utilization of a uniball, they have probably the lowest failure rate when compared to all the other UCA's out there.
Old 11-05-2022, 04:22 PM #26
Deciding between Dirt King, TC and Icons. I still don’t give these companies a pass for selling cheaply made crap though. With all the modern engineering tech in 2022 there should be no reason they can’t engineer a maintenance free UCA with ball joints and bushings that last at least 50k miles. Even with off road use.
Old 11-05-2022, 07:16 PM #27
mrblah's Avatar
mrblah's Avatar
It’s all about compromises and setting reasonable expectations.
Old 11-05-2022, 07:32 PM #28
Nah this is just companies getting away with crap because they can. There’s more than enough of a market for folks who need UCA’s for their lifts and who don’t want/can’t pull them apart for maintenance aside from pumping grease into a zerk. I don’t buy that for a second.
Hopefully more folks end up in my position so we can light a fire under their money hungry behinds.
Old 11-06-2022, 03:54 AM #29
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I posted what I went with earlier in this thread and think this might be what your looking for. They are made in Australia. Aftermarket Upper Control Arms - Why You Need Them | Happy Go Travel
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 11-06-2022, 05:07 PM #30
I’ll need a shop to install them and I don’t know of any that install parts they don’t sell.
lift , quality , spc , truck , uca’s
Downhill tow in 4LO jminz 4th Gen T4Rs 16 08-05-2018 08:21 AM
Downhill Assist 4runner423 4th Gen T4Rs 0 04-02-2014 05:56 PM
MPG going downhill??? BattleCatRoots 4th Gen T4Rs 6 01-31-2013 11:00 AM
Going downhill in low gear BRX0102 4th Gen T4Rs 14 10-21-2010 11:22 PM
Does downhill assist really do this? TeryT 4th Gen T4Rs 17 07-17-2006 06:53 AM
